P1000 My pioneer build
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
2017 pioneer 1000-5. I'm more about functionality then show room shine. First mod was 3500lb winch, then homemade roof, installed fuse block, and ground block, amber led light strip over dash panel and center of ROPS to see wth gear I'm going into and switches at night, backlight on a switch, reverse light while in reverse, digital volt meter, aux led headlights, homemade cup holder for each door, a pulley system for loading deer when I'm alone. I'm forgetting some things but, next up is flip up windshield(homemade), rear bumper and front bumper extension also homemade.
IMG 1749 You Doodle 2017 11 21T02 42 12Z You Doodle 2017 11 23T14 36 20Z You Doodle 2017 11 02T02 02 57Z You Doodle 2017 11 02T02 04 15Z You Doodle 2017 11 23T14 28 05Z You Doodle 2017 11 23T14 27 24Z You Doodle 2017 11 23T14 32 28Z
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
Pic of pulley system for deer loading. And of course camo Honda tailgate decal purchased from thevinylcreator on this forum. Just like everybody else, it's like a frenzy of what I need to buy and mods I want to do lmao. If the ideas would just stop popping into my head lmao my wife wouldn't threaten to run me over with it(p1000)
You Doodle 2017 11 23T14 53 16Z
Reactions: X4Dice and Eltobgi
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Looks like youre off to a good start.
Tuco69
Tuco69
1,474
7,565
Middle Georgia
Nice! Post more pics of pulley system? Interested in doing it too.
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
You Doodle 2017 11 24T15 47 26Z
Paracord tied to ROPS w/ Snatch block and heavy carabiner on right to pull deer up and tie off to the hitch. Then small pulley and carabiner on left also tied with paracord can handle the other end of the deer to pull up and load or tie off to the hitch and let hang. If the deer is too big to pull up by hand I thought about tying off to a tree and pulling against that to raise deer up and tie off. Should work in theory. I like the fact no drilling, bolting, or pieces to rattle with only paracord left to hang permanently. I was going to bolt on a boat winch but believe this setup will serve the purpose
Reactions: moparornocar
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
550lb paracord is the size of that. Prob too small to be pulling against trees tho gonna find out later
Tuco69
Tuco69
1,474
7,565
Middle Georgia
View attachment 58818 Paracord tied to ROPS w/ Snatch block and heavy carabiner on right to pull deer up and tie off to the hitch. Then small pulley and carabiner on left also tied with paracord can handle the other end of the deer to pull up and load or tie off to the hitch and let hang. If the deer is too big to pull up by hand I thought about tying off to a tree and pulling against that to raise deer up and tie off. Should work in theory. I like the fact no drilling, bolting, or pieces to rattle with only paracord left to hang permanently. I was going to bolt on a boat winch but believe this setup will serve the purpose
Thx!
E
elkguide
3,377
7,964
Vermont
Very good look.
You need some Honda SXS decals on that rig!
E
elkguide
3,377
7,964
Vermont
My p1000 goes so much faster sis decal on rear view mirror flew off lmao. Had to install decal in a spot more aerodynamically sound lmao
Both sides of the hood work best for aerodynamics.
Your only other option would be to get a set of RED plastic,
'cause everyone knows that the RED ones are the fastest!!!!!!
Sckottty
Sckottty
53
35
Abilene TX
what did you make roof with, funny, i have almost the same setup, im looking to pit 14”x10” rims on all four corners with 28”x14” tires, ill hunt down another set of ‘16 stock deluxe rear rims to put on the front, worried to see if they will fit with put rubbing.
Amre2me2
Amre2me2
381
1,424
Colorado
28x14 tires will fit fine on the stock 9" front
rims.
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
It’s aluminum composite sheeting my inlaws had. Works pretty good I still need to trim rear corners
Similar threads
Replies
Views
503
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
