Circlip is CHEAP insurance if you are re-using ball joints.
Typically, press in ball joints are one and done. Some have had luck re-using, some have not @my99svt
Looks like the lower ball joint did not have a clip from the factory.
Part #8 is listed as a WASHER, THRUST (12MM).
For the 1000's the clips was included in the 2016, but not 2017/18's.
I just looked at your diagram. I was wrong in my statement. You would have to pull the joint apart before it ever fell out of the lower BJ.Honda sure seems to think you are ok. I think so too.
It's not going to pull out like the top can.
Seems like they would build both joints this way.I just looked at your diagram. I was wrong in my statement. You would have to pull the joint apart before it ever fell out of the lower BJ.
If the upper was similar, it may not leave enough clearance for the CV shaft?Seems like they would build both joints this way.
I’ll be doing mine this week.. I ordered enough c clips to do them all.. we’ll see how it goes though
Wish I could help.. I’m still waiting on ball joints to put mine together. But I don’t think anyone has had this issue with the SATV’s. And I can’t think of anyone offhand that has used the HL arms.Just got my highlighter arms installed. Is it me or are these things crap? The shock mount on the arm makes your force the shock forward to get it in there. My shocks are angled forward rather than up and down. That is the bottom of the shock is more towards the front of the vehicle than the top. These forward arms were built without considering keeping the shock mount in the same place. So it torques the shock and my front shocks won't even compress. My articulation will be zero. Did I do something wrong or is this a design flaw? It seems the superatv arms have the shock mount in the proper place. Can anyone let me know if you've had this problem?
Do u have the uppers on the wrong side? Pics?Just got my highlighter arms installed. Is it me or are these things crap? The shock mount on the arm makes your force the shock forward to get it in there. My shocks are angled forward rather than up and down. That is the bottom of the shock is more towards the front of the vehicle than the top. These forward arms were built without considering keeping the shock mount in the same place. So it torques the shock and my front shocks won't even compress. My articulation will be zero. Did I do something wrong or is this a design flaw? It seems the superatv arms have the shock mount in the proper place. Can anyone let me know if you've had this problem?
@Windrock1000 @snuffnwhisky @ohanacreek @joeymt33 @Hondasxs
Your upper ball joint should be close to inline straight down to the lower ball joint. Typical the upper is just a little further back.Check out the pics. I believe its installed correctly. But on the one you can see two white lines i've added representing the stock angle(ish) and the current more forward angle of the shock due to the shock mount. My front shocks aren't even going up or down when I bounce on the front end. Is there anything else that would cause this? Seems like all the units running the HL arms have the shocks angled forward like this.
View attachment 75917 View attachment 75918 View attachment 75919 View attachment 75920 View attachment 75921
