P1000 Need Parking Brake Designed and Installed
utvmi
utvmi
265
574
So to be road legal in Michigan you have to get an inspection by the Secretary of State, They won't pass a sxs unless in has a separate parking break going to both rear breaks that is cable operated .
If anyone on here can make one of all ready has, Please let me know..thanks
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Don't know if it would work but could change out rear brakes calipers and add cables cheap enough!!! Find one that will work D3d6295aee19694ea2b5529244ffc195
russknight
russknight
1,910
7,511
Perry Florida
I saw on here somewhere, where someone made a parking brake that pushed and locked the brake pedal.
Reactions: Plumber32 and BWAF
Neohio
Neohio
Beast of the East
17,969
86,731
Painesville Ohio
I think Michigan wants a secondary system that does not rely on hydraulic pressure. Or the hillbilly brake or home brewed option would suffice.
DDDonkey
Did someone once install a drive line brake? If not you may want to look and adding a cheap cable system with a second caliber like the drifting folks use.
