TxDoc Well-Known Member Lifetime Member May 19, 2019 2,252 7,532 113 TEXAS 🇨🇱 photos.app.goo.gl Ownership 1000-5 Jul 26, 2024 #21 Did you ever try the paddle shifters and sport mode from a few days ago?? Sent from my motorola edge plus 2023 using Tapatalk
CID Well-Known Member Lifetime Member Supporting Member Oct 27, 2019 5,744 26,371 113 SE Denver-ish Ownership Talon R Jul 26, 2024 #22 DRZRon1 said: So it takes off in 1st gear - does it feel like it’s slipping? When it goes to 2nd gear it just revs and doesn’t move Would be helpful if u posted a utube video of this with sound showing the display My next advice is 1. Clutch relearn if not already done. 2. Dump oil - does it look black from clutch material 3. Inspect clutch packs Click to expand... Runs in first but revs in second, sounds like the 2, 4, 6 clutch pack is toast. Reactions: TxDoc
side chick Member Jul 24, 2024 9 38 13 Pennsylvania Ownership 1000-3 Jul 26, 2024 #23 DRZRon1 said: So it takes off in 1st gear - does it feel like it’s slipping? When it goes to 2nd gear it just revs and doesn’t move Would be helpful if u posted a utube video of this with sound showing the display My next advice is 1. Clutch relearn if not already done. 2. Dump oil - does it look black from clutch material 3. Inspect clutch packs Click to expand... I did the relearn I'm waiting on oil and filters oil look fine I will take a video to day
side chick Member Jul 24, 2024 9 38 13 Pennsylvania Ownership 1000-3 Jul 26, 2024 #24 TxDoc said: Did you ever try the paddle shifters and sport mode from a few days ago?? Sent from my motorola edge plus 2023 using Tapatalk Click to expand... Ya it worked till it warmed up
TxDoc Well-Known Member Lifetime Member May 19, 2019 2,252 7,532 113 TEXAS 🇨🇱 photos.app.goo.gl Ownership 1000-5 Jul 26, 2024 #25 side chick said: Ya it worked till it warmed up Click to expand... As CID mentioned about the clutch packs... You can use the paddle shifters and skip from 1-3-5 AND bypass 2-4?? Sent from my motorola edge plus 2023 using Tapatalk Reactions: CID
DRZRon1 Well-Known Member May 11, 2019 1,434 4,392 113 PA Ownership Talon X Jul 26, 2024 #26 TxDoc said: As CID mentioned about the clutch packs... You can use the paddle shifters and skip from 1-3-5 AND bypass 2-4?? Sent from my motorola edge plus 2023 using Tapatalk Click to expand... Just ride it downhill all the time and skip 2/4/6 - solved Reactions: TxDoc and CID
