FYI
@Doubleheader .
Many have added a rubber mat for under the seat for cab heat, made by a well known member
@trigger, pre-cut to fit Pioneers, just lay it in place. He’s been doing it for years now, started with his P500 and expanded to other Pioneers like yours.
It cuts down on heat, noise and dust coming up from under the seat. It replaced my fabric/foil type which held moisture. If interested you could PM him here or check out his website as well as his post nere on the forum. Highly recommended.
Heat Shield for UTVs. Resistant to UV rays and moisture. Quick Shields are 100% made in the USA. They flat out work.
If you're reading this post then you're probably looking for a solution to the cab noise and heat issue that all sxs's suffer from. Most just accept it as part of the riding experience and a certain amount is to be expected. Then you take the wife or kids along with you and they are far less...
hondasxs.com
