New Product - Tusk Kevlar Terrabite Tires
66,871
Upload 2019 1 11 20 2 6
GET A SET HERE --> https://bit.ly/2FlUB3A
Details
  • The Tusk Kevlar Terrabite tire is the ultimate all-terrain tire for your UTV or ATV. The bead to bead Kevlar belting gives this race tested tire unparalleled protection from sidewall tears while also increasing durability in the tread area. The truck style tread pattern provides excellent multi-surface performance and high mileage while meeting DOT standards. Aggressive shoulder and sidewall tread add protection, and bite in dirt, sand, and rocks. The combination of the proven Terrabite and bead to bead Kevlar belting make this tire a complete package for all-terrain performance and durability.
  • Bead to bead Kevlar plies for ultimate durability.
  • Radial, 8 Ply Rated Construction.
  • Truck style tread for a smooth ride on hard surfaces.
  • Excellent off road and on road performance.
  • High load ratings for today’s larger machines.
  • Tread depth: ¾ inch.
  • DOT test standard compliant (FMVSS 571.119) at max operating pressure.
Available in the following:
  • 30x10x14 @ 34.9 lbs - $169.99
  • 30x10x15 @ 36.7 lbs - $174.99
  • 32x10x14 @ 39.6 lbs - $179.99
  • 32x10x15 @ 40.4 lbs - $184.99
BUY FROM ROCKYMOUNTAINATVMC HERE --> https://bit.ly/2FlUB3A
RM Tusk Kevlar Terrabite Tire3 06
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
Bet I could run these in a 30 and take the high lifter kit off... maybe they will hold up to the bomar Rock abuse.
Probably with the 30’s as I think they run a little short definitely be lighter by about a whole tire compared to your current ones.
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
I wonder if the 30’s would fit with stock wheel on 2” lift? Seems like they should take some abuse.
Reactions: sharp and BWAF
Snuff showed me those a few days ago. My first though was dang it, I recently bought these. Oh well, I wanted the carnivores over the Terrabites but I really like these Terrabites a lot so far.
Anyone want a deal on some 32” Terrabites?!
I am happy to see the innovation. @joeymt33 - what is the weight difference between your and these new ones?
Like to see how Kevlar rides.
I can’t remember what they weight. But those can’t be much more.
272,175
Are you running either one of these on 14" wheels? weight / size should be close:
Note these are the original steel belted version, not kevlar
Tusk Terrabites 30x10x15, 28" diameter, 35.5# weight
Tusk Terrabites 32x10x15, 31.0" diameter, 39.5# weight
Do they show the weight for the 32 inch on 14 inch wheel?
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
Am I remember correctly that you said your 32’s only rub in very few instances.
All - would the Kevlar be tougher to pinch flat?
Anyone have experience running any Kevlar tires, did it give you noticeable flex over steel belted?
272,175
No the spec online only show their original 3 size tires, I got those specs from RMATV via a chat session when asking for Terrabite specs on 15" wheels for a Talon fitment. He had to check for a minute but then spit out the true diameter and weights for those. From looking at everybody's tire specs. any 14" tire vs. 15: tire is a couple of pounds heavier due to slightly more rubber in the sidewall. I am thinking the 32x10x14 tire was 41 pounds, but can't remember exactly. I did tell them they need to update the website for specs of every tire size as the info was over 2 years old and missing 12 new sizes being offered.
Not rubbing now but I had to move be front tire even more forward. I’m about 2.5” forward now.
sharp
sharp
3,757
14,955
Tennessee
You could look up info on goodyear wrangler MT/R off road tires, they have kevlar. I sure the jeep guys have plenty of experience with a kevlar tire.
