P1000 new tire order ?
Buckslayr
141
353
Nd
m going to order 4 28x10x14 carnivore tires with rims, on the order for a honda it comes with 2 with 4-3, and 2 with 2+5, why would that be?I can get tusk terabites with all 4+3 for 500 dollars cheaper,wheres the best value?used on farm and hunting,also what are beadlock wheels and are they necessary?somebody hurry up and answer so I dont add another question>ha
Reactions: ChadD
P1K5Dave
P1K5Dave
2,258
8,457
Petoskey, MI
Couple answers: beadlocks are not needed for your use, more for rock crawlers.
Without going back and reviewing all my offset understanding, if you put all four of the same wheels and tires on a Pioneer, your front stance will be wider than your rear, so I'd guess they're selling you a set to even them out. You can also accomplish this with spacers on the rear. The advantage here is rotatability.
Lochsa88
Lochsa88
44
154
i recently upgraded to 281014 carnivores on Tusk wheels with offset of 5+2. My stock steel wheels were ~1/2 inch diff in overall stance width when i measured. After the swap, they are still about a half inch diff, just in other direction. Fronts stayed same, rear were just narrower by a little over an inch overall. I opted not to add spacers in rear. Half inch was close enough for me. Also, i figured i could always add later, but now don't think i will. Good to have same on all corners, allowing to rotate. Considered the tusk terrabites for much less, but they are not as good in snow as carnivores.
Reactions: ChadD and Buckslayr
Buckslayr
141
353
Nd
I have Kimpex tracks so maybe I will get the terrabites, doesn’t hurt to save a little
Reactions: ChadD and Smitty335
