P1000 New Tires, all 4 same size
Rbol121
Rbol121
61
91
Livonia, MI
Question, can one put 28-10/14's on all four tires on a completely stock set up, 2016 1000-5, without any issues with rims or rubbing. Looking at Evo's or Rocktanes????
T
tbaker
365
637
NW. Georgia
I have 28-10-14 tusk warthog tires on my 2017 P3 with no rubbing they are on 14 inch rims no problems had to trim a little off the front of the factory UTV skid plate the front tire would rub when turning but after I trimmed the skid plate a little no problems
Reactions: CaptJon and ChadD
Rbol121
Rbol121
61
91
Livonia, MI
Thanks, I thought I read somewhere on here that ones were running 28-10-14 on all four corners with no issues.
Reactions: ChadD
Remote
Remote
194
702
Rocky Mountains
Running same size terrabites on 14" Method wheels +1" offset zero issues so far.
Reactions: ChadD
Tramguage1
Tramguage1
Texan
7,496
30,714
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Running 28x10x14 aRip Saws on my 2017 LE. I have added Ricochet sliders an they only rub in full lock extreme conditions
Boss0144
137
147
Commerce Township, MI
I'm about to buy a set of 30x10x14 Terrabites for all 4 corners.
I have high lifter front a arms and high lifter says I can fit true 30's all around. I've seen most say the terrabites run a bit small.
So I SHOULD have no clearance issues?!?
Anyone think otherwise?
I've got a pretty bad gash on one of my rear stock tires. Rather than replace it, I might as well upgrade them all, right?
Thanks!
Reactions: Ragnar406
Yes 28” Evos and 28” Roctanes are true 28” tires the 30” Evos are about 28.75” at 10psi and all should fit stock, but the 30” Roctanes are 30” and you need forward offset a-arms.
Reactions: JTW
208,728
I doubted the 28.75 until I measured, exact at 8 psi, but you still need the forward a ams for pure pleasure, I don't notice a difference in turning radius on the trails. I think the added length, 3 inches makes it a more comfortable ride.
RickMaynard
101
121
Arkansas
I am running 28-10-14 reptiles with a 5-2 offset all the way around. They are about 27.75” at 10 psi, no issues.
Boss0144
137
147
Any thoughts on running 32" Terrabites (stock deluxe wheels) with just High lifter front A arms and a High lifter lift kit??
Anyone know how tall they really run? Maybe add some spacers?
Any other issues? Clutches? Lack of torque with bigger tires? I'd like to think it won't be enough of a loss in torque to bother me. My riding is more trails and roads in Mi. Some woods where I'd like the improved clearances. But not big mud, steep climbs, or rock crawling.
Thanks.
Rbol121
Rbol121
61
91
Livonia, MI
Thanks.
I can't help ya bud, I have been throwing around the thought of all four tires being same size, including spare, just for simplicity reasons. I want to go to 28's but keep stock rims and set up. Your's sounds like a good set up but can't help ya with your question, someone on here will though.
RB3offroad
RB3offroad
1,714
4,819
Tempe, AZ
Thanks.
check rb3offroad.com for Spacers
Reactions: ChadD and Rbol121
A
aajumper
charleston, wv
2020 Pioneer 1000-5 DLX. Stock wheels, 5-2 front, 5-3 rear offset rims. Want to put same offset rims all around so I can rotate tires. Is this possible?
Reactions: Kskaggs and ChadD
RickMaynard
101
121
Arkansas
I have 28x10x14 on 5-2 offset all the way around. No problem. With that set up, front tires stick out about 1” more and throw more mud than the rears but if you like the even look, just add 1” spacers to the rear.
