P500 New tires mounted by hand - 27s
RTM1500
RTM1500
21
60
Treasure Coast
6E39D599 06A3 448B B957 DB6535AA9A5F 3C310043 3A7B 4CE2 9361 F7C4FD942944 00B16A49 2D6F 4B6C A724 69DB26E098AC 21A7FCA4 6BF3 4466 ADB7 14CF373AAE50 AF469124 3D36 4586 8DB1 66369FE16959 B103F98E 5A3C 41B5 A380 328B5363FF92 Just mounted up some 27 zillas with a manual tire changer from a local harbor freight. This is a great tool for stock steel rims. If your not careful you can scratch the rims easily. Great tool for cleaning out the bead if you get some wood or mud in it.
41B7392D 2FFF 4403 95E2 4D06BE5BBEBF
G
Gassygordo
302
1,025
Fillmore, NY
Yup, excellent tool! I have one mounted to the floor up stairs in the barn. Has changed many ATV, UTV, motorcycle and auto tires. The neighbors use it also. Bought mine at Harbor Freight years ago.
116,574
I have one of those also. Did all my 30” Beadlocks on it. Just a little muscle and patience (I don’t have) will get er done!
NitroxDiver
NitroxDiver
488
918
Concord NC
These do work well if you have room for it but if you are limited on space you can use a hand operated bead breaker and two tire spoons. Last set I installed this way took about 30 minuets from start to finish. I’ll try to find a picture of the bead breaker.
Reactions: swsebek
NTC/TAP Transition Member
11,883
90,594
Does their 20% off coupon work with that?
RTM1500
RTM1500
21
60
Treasure Coast
20 percent coupon does work for this tool .. comes out to like 33.68 or something like that
Reactions: Mudder
L
Lemley
6
Pa
Would like to see a pic of the hand operated bead breaker
