P1000 New tires!!!
Rohr84
Kentucky
I just bought 28/10/14 qbt 846 and mounted on stock deluxe rims not happy with how the back tires look on the wider rim my question is what size rims will I need to get to make tracking as close to stock as possible without the wheel spacers in the rear thanks prefer same size wheel for rotating tires
Reactions: ToddACimer
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I'm not sure I understand what you're asking.
If your goal is the have the front and rear tires in the same track AND be able to rotate the tires to any of the 4 corners you have 1 option.
Buy 5+2 offset rims and put 1 inch spacers on the rear.
You cant put the factory rear wheels on the front of the machine. You could buy another set of factory front wheels for the back but you will still need spacers.
Rohr84
Kentucky
Thanks
Rohr84
Kentucky
what offset would I need for proper tracking and would 7 wide rim be ok not to worried bout rotating tires 5+2 front 4+3 rear?
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
Thank you
You can go with a 6+1 but the machine will look pretty narrow.
This is 14x7 5+2 wheels with 28x10 QBT
IMG 20191019 171617
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Buy 5+2 offset rims and put 1 inch spacers on the rear. This is the best option.
I'm with todd. Just get the spacers. Using different offset is just a cluster f***. You may not care about rotating but at some point you may need to move them around and your life will be a lot easier.
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
Any downfall of wheel spacers is easily offset by having 5 matching wheels and no fears of having a spare tire that fits. The spacer also looks good with the track width the same front and rear
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Agreed.
Sjc3081
Sjc3081
263
442
Wappinger NY
5+2 front wheel will increase your front width to 66” from factory 63”. That why you need rear spacers.
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
What psi are you running and what do the tires measure. I really like this look and have been back and forth on tires for my 1000-5deluxe
With fox shocks I ran 10psi. With Elkas I'm running 14. The tires are just over 27" tall and close to 10" wide on 7" wheels
