P700 New Tires
Ekimdoog
Ekimdoog
32
71
Freeport, ME
I have a 2022 P700-4, I want to swap out the 25" stock tires for 27" with a tread pattern closer to turf based on the use of the SXS. Can I put 27" tires on this machine without a lift kit of some kind? will tires rub? Does anyone have a recommendation for a tire that is much less aggressive and closer to turf tread? thanks for any info. Mike from Maine
Reactions: Backwoods
Ekimdoog
Ekimdoog
32
71
Freeport, ME
Replying/adding to my original post..............can I buy 14" wheels for the 27" tires and mount those in place of the 25" originals? Do 14" wheels come with the correct lug pattern and offset? thanks agian
Mudwisel
Mudwisel
8,652
74,287
Tampa Bay Florida
Yes you can get 14 inch rims with 4x110 bolt pattern. I would suggest you get 1 inch wheel spacers for theRear and the same offset for all 4 wheels. Stid will make the track the same front and back. Also look into the tusk terrabites. Yes 27 inch tires will fit no problem
Backwoods
Backwoods
35,074
356,366
Douglasville ga
My old 700. 27’s and you could not make them rub. Much better than the stock too small tires
DFCE9D87 2F64 40AD 9613 8CB5A345A4EC
KevP700-4
KevP700-4
249
610
Northern MI
I'll be buying tires soon for our 700-4D. My plan is to get Tusk Terrabite tires in 27x9-12 for front, and 27x11-12 for the rear. There should be no rubbing and the tread is about as close as you can get to turf style tires, but still trail worthy. Give them a look and also do a search here on the site for photos of the same. The Terrabites are a long lasting tire.
Luka
Luka
29
80
Wittenberg, WI
2 years ago I put Quadboss QBT846 tires in 27x9-12 for front, and 27x11-12 for the rear. Not even close to rubbing. They're like a light truck tire, 8-ply radials that are also great for diving on pavement and will last many more miles compared to the stock tires. Last month I plowed 12 inches of heavy wet snow in northern Wisconsin and was quite pleased with them. The tread design is also much easier on my lawn than the stock tires.
KevP700-4
KevP700-4
249
610
Northern MI
Another good choice. The tread on the Quadboss tires looks allot like the Terrabites
Reactions: Buggyman
measel
6
12
Sherman, TX
I used adapters to go from 4/110 to 4/137 so I could use 17'' wheels ( more tire options ). System 3 ST-3 with 27 Terrabytes. Slightly wider stance.
IMG 20240409 155654961
Much beefier ( beefier ? ) look I think.
IMG 20240409 155632828
