What size/brand of battery does most folks use for a dual set up under the hood? My true isolator should deliver next week. I plan on adding several lights and a radio, plus fans under the seat.
Amazon.com: Odyssey PC925L Automotive Light Truck Battery: AutomotiveWhat size/brand of battery does most folks use for a dual set up under the hood? My true isolator should deliver next week. I plan on adding several lights and a radio, plus fans under the seat.
I'm also ordering a True isolator, where do u plan on putting second battery, under driver seat or under hood?What size/brand of battery does most folks use for a dual set up under the hood? My true isolator should deliver next week. I plan on adding several lights and a radio, plus fans under the seat.
He was asking for underhood..I'm also ordering a True isolator, where do u plan on putting second battery, under driver seat or under hood?
Thank for the response, I was wondering what size would fix there. Any tips on securing it in the hole?
I used a tie down strap and routered a hole on the forward side of the battery hole.. mine runs over the bar behind the battery (that's where the plastic ends and the rubber meets) and under the battery hole then over the front bar where the strap hole is routered. In the first pic below the relays where the buckle is, there is a little shelf, under that shelf is the metal bar I'm referring to.Thank for the response, I was wondering what size would fix there. Any tips on securing it in the hole?
That makes things a lot easier to work out. I had thought of a few things but hadn't located the bars yet. Thanks again.Hope that makes sense.. I'll have to take some more pics if you need some clarification. This is just what I had already on my phone. If you feel under the plastic via the wheel we'll you'll feel the two metal "bars" I'm referring to.. they run on the front and back side of the battery hole.
Hahaha, Wow, Drinking and reading this forum doesn't work for me. I see clearly now where he is putting it!He was asking for underhood..
You'll fit right in then!!Hahaha, Wow, Drinking and reading this forum doesn't work for me. I see clearly now where he is putting it!
I added a second battery. My thought was even if you can get away with the stock battery to run everything, I'd rather have the reassurance that I won't run out of juice when I'm way up in the hills somewhere. It's not a terribly expensive add-on either for the peace of mind....Gotcha, So here's my next question. On my P700 I had Winch/Plow, sound bar, LED's around the house, Voltmeter panel. Do you think it would be wise to add a second battery for these accs. if low voltage affects the shifting?
No.. the winch solenoid is in the upper left corner behind the battery.. it's on one of the frame uprights... the solenoid in the center of the pic you're seeing is basically my on off switch for all my accessory power. Winch stays hot directly to the battery.. fuse/relay box is to the left of the solenoid you're speaking of where the intake cover use to be.. and the accessory solenoid is just breaking the feed line to the fuss/relay box via a switch on my switch panel.JTW, is the device (Relay /solenoid) above and to the left of you True isolator for your winch?
Sorry to revive this thread, but I'm researching a lot on dual battery setups. Think I've got a lot of it figured out but what is the black square below and to the right of the True Isolator in this pic?? (It has 4 neg lines, 3 large and one small, and 2 large positive lines connected to it).
I used the battery feed side of the winch contactor/ ISO as bus points for the power system. to reduce the length of wires and points of corrosion.
There is a short 4ga wire coming from main battery to ISO and main battery to neg side of contactor.
The way mine was set up the only reason for the connection between the two batteries is to charge the secondary battery(which feeds all added accessories) only when the main battery is above 12.8v
Okay, winch contactor, makes sense now. I think I'm tracking most of it, just a few more questions to make sure..
When you say bus points for power system, do you mean to your accessory fuse block?? Is that where those smaller gauge wires go?.
I get the one going to the ISO. I don't understand why the Neg from the main battery to the contactor. Why is that one needed? .
And the only 'connection' between the two batteries is through the True Isolator right? Am I seeing that correctly? If so that makes total sense and that's exactly how I want to set mine up.
