Noisy idle
Scottjs
5
0
Greenville, NY
Does anyone else's talon seem to be noisy at idle? I hate to use the word "knock" cuz it's not loud enough to be a rod knock. But it seems noisy in the crank case only at idle.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
270 degree offset crank.
It exercises the valve lash at idle.
(Also has good low end torque)
Scottjs
5
0
Greenville, NY
So you're telling me this is nothing I should worry about? Just the nature of the motor? It gets louder when it's warm but doesn't happen at higher road
SLOWPOKE693
SLOWPOKE693
1,642
6,299
Somewhere in Texas
Have you checked the valve lash recently. It might be something simple like a valve adjustment...
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I merely meant that it idles louder and rougher than an in-line twin or 180 degrees motor.
compare it with another one.
What he said.
Reactions: Scottjs
I know the noise your referring too, ive heard several just like it.
I wonder if it could be timing chain tensioner.
