So I finally started adding stuff to the new ride. Starting out with the storage compartment under the drivers seat. One of the hex head bolts that holds the trim on must have been put in with a breaker bar and Loctite. Stripped that sucker almost instantly. Used a socket, not an allen wrench. How tight? Put a stripped screw extractor in, tried to pull it out, the drill started smoking and I broke the extractor. I was able to work around the trim and install the compartment. The chunk of broken extractor is still there.
Started pulling everything to install Honda horn kit and a SuperATV 4500 pound winch. Right fender and door, no problemo. Left door, first bolt, same thing. Must be torqued way down and installed with Loctite. Rounded the head off. Yes, I was using a 6 point socket. Had to put a rounded screw extractor on it to get it off. Gonna replace all 8 bolts with some quality bolts, not more of this cheap Chinese crap.
Get the shifter knobs off, go to pull the 2 hex bolts around the shifters that hold the panel on, they were pre-stripped from the factory. Wasnt that nice of them?
WTF is going on with Honda? The service manager told me at delivery to watch the hardware, they have had problems with it stripping. Are they cutting corners and using cheap Chinese hardware? I never these problems with my 700-4.
