P1000 OEM axle lenghts
lukpy8810
lukpy8810
91
203
Minnesota
Quick simple question. Would anyone be able to let me know what the stock rear axle lengths are (driver and passenger)? Thanks!
115,308
Obviously its not
Why cant you measure yours, did u loose them both on trail?
What rig, LE or not LE?
Do u need the measurement from spline end to spline end? Or while in the sxs?
I Cant remember if both sxs’s are the same?
Id have to pull mine to check.
NoHmo
Maybe someone has an extra pair lying around they can measure for you.
lukpy8810
lukpy8810
91
203
Minnesota
Obviously its not
NoHmo
Lol sorry its a 2018 deluxe. And it's at the dealer for some work and when I bought it it had aftermarket axles installed and I'm trying to determine if they are what's causing me issues. The dealer I originally bought it from was pretty poor. So I'm checking to see if they were dumb enough to buy 2 lefts or 2 rights for the rear since I know they are different lengths. But maybe it's not even possible to install the wrong axels lengths in back it's been unclear if that's possible or not.
Reactions: Rayger143
115,308
Your right, not possible with a P1k3 or P1k5.
Do u have 3 or 5?
Do u have a lift or aftermarket arms or stock?
What issues are u having?
lukpy8810
lukpy8810
91
203
Minnesota
Do u have 3 or 5?
P1k5 and stock ride height. The rear diff was acting funny. Wouldn't unlock it's at the dealer right now. But I think it may more likely be a cable at the end of it's life and over stretched as I'm out of adjustment lol
115,308
Did u try searching how to adjust that on here? Its real easy and a video too
ODAMO
ODAMO
1,283
3,450
Ohio
Yeah but I think the cable is over stretched as I can fully tighten the one to the rear diff and not pull the locker out far enough to disengage
On the 22s on there is an adjustment at the diff and this is what I did because the cable seemed to be too long. Maybe something similar will work on yours.
My solution was to take a 3/8” dia. ss bolt and cut a .800 long piece from the unthreaded section , drill a .236 hole in the middle and inserted it in between adjusting nut and the stock joint pin.
This method still retains the anti rotation to hold the setting and allows for plenty of adjustment.
066da9e8 e173 43a3 84b8 c4f791ff7147 jpeg
lukpy8810
lukpy8810
91
203
Minnesota
Well own a couple 3d printers I'm betting I could print something like that. I have a couple other printed parts on the rig already. Should post some photos
115,308
I thought you seemed familiar! Your the one that keeps making new threads that pertain to the same issue if your main thread. Try to Stick to one thread! 🤯 Thats why u havnt got many likes or responses here. People are like WTF. 🥳
Dont worry, it wont clogg the other thread. It will help others with the same situation.
You dont even have pics of your rig yet. We know u said its at the dealer but still, you might be a poo poo infiltrator as far as we know 😂
Pics Or It Didnt Happen!
You cought me under the weather and I took a bite. 🤨
lukpy8810
lukpy8810
91
203
Minnesota
I have pics attached to my profile! And understand able. Just trying to learn and gather info. I thought forking off with other questions would be more useful evidently not
115,308
Do a welcome thread like others and post your pics, mods, miles and about yourself.
Not trying to scare or demean you. Just trying to help u out so u can get some answers to your issues.
Theres a Hello thread that explains what we ask for such things. Last 2 posts.
lukpy8810
lukpy8810
91
203
Minnesota
Oh no you're good! I'm just learning how this works. Is there a specific place I should post to for a welcome thread? Also how do I know my photos are visible to others lol
5,406
24,778
Introduction and Welcome, right under General Discussion.
As for knowing if we can see your pics, ask in that post and we'll tell ya - Hey, can you see my pics? :cool:
208,725
I've got a brand new right rear, the left rear is a different length.
Reactions: Remington
