P700 OEM FENDER FLARES AND 26" TIRES
Lynn1130
Lynn1130
126
171
Phoenix, AZ
It is time to replace my OEM tires and I have been looking at 26" tires. I was also looking at 27's but I am pretty sure they will rub the Honda fender flares that I put on. Now I am wondering if 26's might do that.
Does anyone have the OEM flares and oversized tires? Did you have issues with tires rubbing on turns?
Thanks for the help.
tjoreo
tjoreo
1,025
1,975
Southern Idaho
I have the OEM flares and have 26x9x12 and 26x11x12 on my rig with no issues at all. I don't believe it is even close to coming in contact but I check tonight.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I have the same.. 26" ripsaw tires and OEM flares...no problems... I don't think 27" tires would rub either..
Remember, all tires are different even if they say...26" or 27" or whatever..they will measure out a little different and sometimes a lot different.. Just FYI
Reactions: Mudwing
Lynn1130
Lynn1130
126
171
Phoenix, AZ
Yes, but also remember, if I buy 27s and put them on and they rub, I am screwed so I need to be sure and not just "I don't think"
Ems-Cam
Ems-Cam
252
336
Alberta
I just upgraded my tires, STI Rocktane XD 26 x9-R12 front and 26x11-R12 in the rear with STI bead lock HD rims. Love the ride now. Should have done it sooner. 0090c2318711bbc4faaed02a67fafb07
tjoreo
tjoreo
1,025
1,975
Southern Idaho
Checked my 26" tires and I have about 3 fingers (2.5") behind the tire and the flare. I am running stock everything except went to a little bigger Maxxis Ceros tires. I also run them with a higher pressure, about 15, so this will take up a little clearance. I can't speak for 27" but I have plenty of room with my setup.
Max718
Max718
246
366
Mississippi
I have 27x9x14 Roctane wit OEM flares its some places we ride that do rub some not much
Reactions: Mudwing
Lynn1130
Lynn1130
126
171
Phoenix, AZ
IMG 0919
Thanks everyone. I decided to go with 26 and not risk the 27s. I appreciate the feedback.
Reactions: Deluxe700
