V
Hi Guys,
New guy here on the forum and to SxSs. Planning on wiring up a winch and have read through many posts about doing it. Currently assembling the supplies needed, isolator, relays, fuse box, protective boots for connectors, etc.
Couple Questions:
I have the power On harness from this site plus a couple other goodies. My goal is to take the best ideas from all the info I can find and do a nice clean and simple install on the newly wired accessories.
Thanks!
Any info is appreciated.
-Vince
Couple Questions:
- Is there only a Pos cable coming from the battery compartment or is there also a Neg? I understand the Pos is taped off and not connected, not sure how long it is, but noted it is located in front of the steering wheel under the hood.
- What gauge is the OEM Winch power cable? Ring terminal size? I will likely upgrade the gauge from the Aux battery to the winch relay, and to the winch motor.
- Does anyone have a favorite or recommend a Aux battery box? I plan to use the same size battery as the OEM, not planning on having a lot of electrical load besides at few lights and the winch. Probably don't really NEED the Aux battery, but WANT one.
Thanks!
-Vince
