P1000 Overheating question
Big_Daddy
Big_Daddy
42
Clayton, NC
i rode my new p1k out at the outer banks this weekend and have about 60 miles on it now. While I was out there it overheated on me, and I've read about people having air trapped in e coolant lines causing that. I'm going to check that, but what concerns and has me wondering is that the only thing I've done to it before this ride was put the vent hose extensions on and put a heat insulation material under the seat and up the back side of the seat. Wondering if the heat shield material not letting that heat come up through the seat could be keeping it trapped under there and make it run hotter than it normally would. I as running 25-30mph, so I wouldn't think so but thought I'd see if anyone else has noticed theirs run hotter since putting that stuff under the seat.
Thanks
E
elkguide
3,377
7,964
Vermont
Can't see how what you fixed would have any bearing on overheating.
66,870
No. Shouldn't affect it. 60 miles seems like a bit far to just now have a burp issue..... Unless you have been fairly easy on it in until this weekend.
Been in any mud? Check back side of radiator to ensure not clogged.
Do u have a winch? Winch it up and shake it around. Check coolent. Or find a steep hill to get the front end up high. Check coolant.
There also have been a few reports of fans not working. These were just wire issues. Usually just unplugged somewhere.
Also 2 reports I know of thermostat was defective. Or so said their dealer.
Lastly. Where are you riding. Private or public area? Are you able to ride on the beach? If so, how far. We had a topic looking for info on this somewhere.
Can I come ride with you? Lol
Thanks.
Reactions: Crow_Hunter
Big_Daddy
Big_Daddy
42
Clayton, NC
Thanks.
I've been extremely easy on it til this weekend. Only rode 8 miles prior to this weekend in fact. Did get in some mud and actually stuck in that first 8 miles, but that was because I went through a place that didn't look like mud because it had vegetation growing on top of it and I thought it was solid ground. I cleaned it very well afterwards though.
I could hear the fan running so don't think it's that. I'll run it up on ramps and check the coolant. Do I need to run it up t temp with the cap off or anything?
Yes we rode on the beach. You can take the Davis island ferry service over to the island that cape lookout lighthouse is on and ride all over it. About 25 miles from one end to the other. You can camp out there and rent cabins as well which only have bunk beds unfortunately. There's also Portsmouth island just north of that has ferry service from Atlantic, NC and it has cabins you can rent as well, some of which have electricity and AC. There's an old abandoned settler village there to explore.
Reactions: elkguide
