P1000 P1000 valve adjustment?
Riverrat
Riverrat
86
234
UP of Michigan
Has anyone done a valve adjustment on their own? I don't trust my dealer to do it when the time comes to do an adjustment. Is there good instructions in the shop manual?
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
I have been curious about the same thing. I think a member posted something on it awhile back. Would be nice to get a full description and or tricks to do so on the P1K3 and 5.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I have adjusted mine! Very easy! There are 4 adjustments--the manual has very good instructions with detailed pics! 2 of the adjustment require shims where as the other 2 do not!
IMG 5291
You'll want to remove seat, air filter housing, and all plastic shielding for ease of access.
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
Eltobgi, when you did yours how many hours /miles did you have on it? Where the valves out of adjustment and did you notice any difference after the adjustment?
slowandeasy
185
188
Palm Bay, FL
so that people understand what is involved.... one set of valves have rockers and can be easily adjusted. the other set rid directly on the cam and have to have a shim cap placed on the stem of the valve to adjust for more/less gap.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
1200 miles...it was having trouble starting, yes I did adjust 2 of 4! The 2 shimmed did not need to be adjusted as they were within specs.
Since adjustment no trouble starting:)
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Great thank you. So what kind of starting issue? Long crank? No start? Or rough uneven idle? Just curious. Just have these questions due to my profession. Haha
Long crank, rough idle, stall, & smoke from exhaust smelling really rich!
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Well they were outside of the allowable margin! I should have documented it to share as a before and after! I will say that overall the adjustments were not difficult...just follow step by step instructions;)
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
Thank so again for sharing. This would be a great topic for the how to thread
208,726
Did you have to adjust them?
K
Kepper218
9
14
Silver Bay MN
Heres the deal, the updated service manual for 2020 that is supposed to cover 2016-current calls for intake lash to be .006 and exhaust lash .012. Old service Manual was the same except exhaust lash was .009. Anyway I just did the first service and all the intakes were at .006, 3 exhaust at .009 and one at .010. I adjusted that one to .009 buttoned it up and started it up. Seemed just fine. The next day I called around to a few dealers and got mixed results with some saying .009 was correct and some, including the place I bought it from telling me .012 was correct. I readjusted them to .012 and it seems just fine. Anyway, you can access the valves by pulling the seat and backrest, shield that is in between the backrest and seat and you'll want to pull the plastic shield held on by 4 push pins off the back of the airbox so you can see timing Mark's on the camshaft gear. Anyway it's about a 2 hr job if you take your time. 3 hrs if you haven't removed any off the shielding before and had to reinstall it. You'll need a flathead screwdriver or pushpin removal tool, 10mm socket for valve cover, 8mm box wrench and 3mm tappet wrench for the valves. I used a very small crescent wrench, I don't have a 3mm tappet. A 6mm Allen to get access to the crankshaft peephole, I think it was a 22mm socket for the crankshaft cover but a larger crescent works, and it was either a 18 or 17 mm socket to turn the motor over to line up the timing markes. A feeler gauge to check lash and that's about it.
helimech
helimech
110
190
thank you, great info . I plan on doing it myself also. if i can fix a Helicopter I think I can handle this.
0860silverado
954
1,834
louisiana
Now THIS...THIS is the type of reply that should be applauded. Thank you!!!
