P1000 won’t start
P
Possumjohn
USA
Over the last month I have been working on deer stands. Twice now I have got ready to go home and after riding on and off I have started SxS and it started but died. I can crank it over but it will not start until I pull to trailer and winch it on and drive home and it will start right up.
Anyone had this problem?
115,286
☝️☝️☝️☝️THIS☝️☝️☝️☝️
P
Possumjohn
USA
2019 359 hrs
No lights
Last year i had the same issue.
Honda shop diagnose was a bad battery.
I had serviced and plugs changed and new battery. Never had a issue until a last 4 weeks.
This time I checked the battery and both times the battery voltage has been good. I have it at the Honda dealer now but they called this morning and battery is good and no codes and sxs has not failed for them.
I have noticed the fuel pump doesn’t sound as loud when this problem occurs. I can normally hear it from driver seat when I turn key on but when it has stranded me it hums but I have to raise the seat to hear the pump. I told the shop that when I dropped it off to them but I’m afraid without a code or a machine that fails for them I will be picking up a machine that might make me walk.
Reactions: JenElio
66,813
Have you had your recalls checked?
P
Possumjohn
USA
They did a steering recall but to my knowledge never done anything to fuel pump.
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
Does your servicing of deer stands r.equire a lot of starts, with short runs in between? If so, they are prone to fouling plugs.
