P1000 P1000k5 lift with stock
E-this
E-this
6
11
I'm running a 2019 5 seater with stock rims and tires what is the best way to get lift ? Or what largest tire size you can go without putting a lift on it?
PS new at all this trying to figure things out
Reactions: sharp and BWAF
E-this
E-this
6
11
I'm also confused about the wheel spacers I see some people running 2in in the rear and 1.5 in the front? Why not 2 in all around?
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
Are you keeping stock wheels
Reactions: sharp
BWAF
BWAF
8,869
42,496
Carthage MO
I dont know as of right now .. I would like to set it up and be ready for the new set if i want to. Small steeps
Okay well the spacers are because the factory wheels have a different offset front and back if you buy four wheels with the same offset you will need at least a 1-inch spacer on each side in the rear to make the front and the rear the same width . I think most people would agree a true 28in is as tall as you can go Factory
E-this
E-this
6
11
Awesome thank you ... with the lift kit should I put the 3in spring spacer on it Super ATV has it for 189. I do miss the trail riding / mud
Reactions: BWAF and Remington
116,574
Do the spring spacers. It’s the most economic way to do it plus you get a better ride out of your springs. You can make the spacers out of Black gas pipe or buy them
116,574
What size pipe works best?.. This may be the next mod..
I can’t Remember exactly? I think it is 3” id pipe for the rears and 2 or 2-1/4” id for the fronts. There’s a thread on here for it if you search. I’ll see what I can find.
Reactions: BWAF
Bocifus
Bocifus
N. California
2" for fronts 3" for rears if you have the load leveling shocks. 2" all around if you dont. For every 1" of spacer double that for the lift height.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
easy way to do the spacers is to use a trailer ramp. and 4 ratchet straps. and a jack. articulate the bike as much as you can loosen the nuts on the 2 compressed shocks. put the straps through and use the ratchet to tighten. then back off the ramp and use the jack to extend pull bolt and add spacer. took me about an hr to do all 4 on my 700-4 like this. D419792c958a5a197c4f732303340a09
Reactions: BWAF and Bocifus
