P500 P5 finally arrived
Shive
I picked mine up Tuesday. We just got back from Arizona and it hadn't come in yet so we didn't get to ride it there. I guess we'll have to go back.
I just put 26x9x12 Carlisle versa trails on all four corners to stay at 50". It measures 50 1/8 up front and 49 1/2 in the back. I could have gone with 11's in the back, but I want to be able to rotate them since I ride a lot on asphalt. Stock rims and no spacers. Clearance on the fronts is fine. Honda windshield and soft top. The bed came off of a mid 90's EZ go. I need to make some sort of tailgate for it, but it's ready to go aside from the powder coaters. Also installed a glove box and I made a storage space under the hood with a sheet of polyethelyne.
20190315 160432 20190315 160454 20190315 160523 20190315 161247
ehart814
ehart814
1,653
3,630
NWPA
Looks nice. 26x9 is a great size for the 500. Those tires look pretty nice. First time I’ve seen them installed on a machine. Put some miles on and report back!
The factory front rims are not the same as the rears. If u want to rotate, you’ll need to get rims that are all the same.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
View attachment 115114 View attachment 115115 View attachment 115116 View attachment 115117
Great unit and based on the thread, you are excited! I am curious, what make/model ezgo bed did you use and could you post a few additional pictures of it?
Reactions: Shive and sharp
208,718
Look
Looks Good!
Reactions: Shive
Shive
I got it out of a dumpster at the college I worked for. I'm just guessing since they had ez go carts at one time. I'll post more pics after its been powder coated.
Reactions: 500oneer and Mudder
Shive
When it's time to rotate I'll just remount them. I have a good friend that has tire mounting equipment. It only takes a half hour.
Reactions: DaveM47
alloutdoors
alloutdoors
1,022
2,184
US
Can you measure the length and width and post those numbers? Reason for asking, there are several beds out there, but finding a nice match for the P500 is highly desired by many....
tomcj2
tomcj2
325
731
What is the difference between front and rear?
If it is only the "offset" could I use spacers on the one pair of wheels when they are mounted on the 'wrong" axles?
I like the idea of being able to rotate my tyres but dislike the thought of spending money on alloy wheels.
Reactions: Gassygordo
ehart814
ehart814
1,653
3,630
NWPA
I can’t remember exactly, but I think maybe the rear wheels are an inch or two wider, and the offset is slightly different
Shive
It measures 44 x 31. The size is almost perfect. There are several that measure 41 or 42 wide for various applications but none 44" that I have found online. I think a 42" would look fine. You can find them in aluminum and steel reasonably priced that fit Yamaha, Club car and EZ go.
Shive
Got it back from the powder coaters. I had them use semi gloss black to hide some of the dings in the bed. I mounted it on a sheet of poly I had laying around to eliminate vibration.
20190320 121737 20190320 121831
