P500 P500 mud buster front flares
K
KPM
41
125
Prairieville LA
Anyone own these and have an opinion- standard vs extra coverage. I have 27s no spacers. Looking for advice before I buy. 7c34a1f43484e788086a98123571d1c2
K
KPM
41
125
Prairieville LA
I used a different search and found some feedback for p500. Not as good a google so if you change up the search such as mud buster vs mud buster fender flares it yields different results. Merry Christmas.
P
pappyo
593
2,377
Online at :
SpeedwayMotors.com
Airdam/Body extention Plastic
1/8in Thick x 22in. Wide x 25ft. Long roll. SMOOTH texture
Black was under $75.00 shipped to door ( guarantees 2 Day Del. )
Other Colors & lengths available.( $$$$ varies)
Durable & Flexable -- stiff enough to hold desired shape using a heat gun.
Easy to work with -- Heat Gun -- tin snips & or sabersaw.
Only your imagination & fabricaton skills is holding you back.
Mud Guards
Fender Flair's
P520 Box area above & in front of Rear Tires (prevent mud build-up up )
P500 Floor protcctors ( P700 too )
Unlimited uses! Atv/UTV-- trailer -- Truck
LESS -- $$$$ than 1 set flairs or mud guards
View attachment 322476 View attachment 322478
Enter "MUD GUARDS" to find boat load of in put & ideas
Reactions: Smittyp
futzin
futzin
3,157
22,708
Kentucky
Anyone own these and have an opinion- standard vs extra coverage. I have 27s no spacers. Looking for advice before I buy. View attachment 367612
I have the extra coverage ones. Love them. They have held up well to various trail scrapes. 27×9×12 front tires, no spacers.
20220826 170140
K
KPM
41
125
Prairieville LA
Thanks for the comparison pics. Exactly what I’m looking for. I ordered extended coverage.
Also those strong made bumpers look so awesome. I have a long list of wants!!
K
KPM
41
125
Prairieville LA
Reporting back. I installed the xl flares the weekend before an annual ride - mud/ water / sand and also tried them at the hunting camp where the mud is thick. I have to say they work well and more importantly they keep mud and rocks from hitting the frame at the very bottom
By the rocker panel. Absolutely love them and the install wasn’t bad. I did have to the bolt at the top of the fender welded and mud busters mailed me out a nut to put on it since I couldn’t take it off great customer service, clean factory look. Didn’t do the rear as it seems a bit involved. The fronts cut down on most of my mud on my arm and body!
64942f5a0ca22e3d70931f42149e4845
Ca47a42e736d5790046b8b5e6e58c232
JCart
JCart
897
2,024
Kamloops, BC Canada.
If you can buy thin UHMW like 3mm thick, it’s so tough! Made my own fender flaps to reduce the keerap and they’ve worked well. I extended a rubber (flap) on the bottom 6”, so when backing up over a stump if it “pinches” it’ll just pull the end off rather then pull the entire piece off. Held on with Honda push pins and stock bolt on top of arch.
Over the years have bought 4’x10’ sheets of black 3mm thick UHMW for a variety of projects, like cab enclose, fender extenders etc. Easy to work with and tougher than spiral nails..
80451E62 3050 4BFC 9A51 699DAB19CF10 49BDCD0B DBCC 4EF8 8394 2E77CC941BA4 CF964A08 0602 4A86 8BAF 00115830A9C5 164719AF 343C 4EE2 B467 E354991C9BDC
K
KPM
41
125
Prairieville LA
@JCart would you happen to have a better picture of the rear mud flap you fabricated. I’m planning to make a flap for the rear.
Thanks kpm
JCart
JCart
897
2,024
Thanks kpm
@KPM,
This is all I have, apologies, not near the Dozer until mid March as I’m on vacation.
As I recall I discarded some factory plastic, none the less does reduce keerap flying forward off the rear wheels. Was reluctant to have them hang down low to minimize damage sliding over logs and other obstacles. Also they can divert dust upwards at speed, however my cab (at the rear) does limit it somewhat. Because of the Venturi effect of wind rushing over (and around) the cab dust is pulled up anyways (image was pre cab). Overall I’d do it again.
Cheers,
j
94E2395D AA39 4FFC 95F5 600CD0F13A70
Reactions: 500oneer
K
KPM
41
125
Prairieville LA
Perfect thanks I’ll try to report back when I’m done. I’m in the same boat waiting for some free time to take this on.
