![bowhunterbill](/data/avatars/m/18/18282.jpg?1603072500)
I’m posting here instead of Shop Talk- hope this is the right place.
I was riding the P5 Sunday, driving on dirt road in 4th gear (manual shifting). I noticed the display went from a number “4” to a solid dash- no blinking. I could not upshift to 5th or downshift to 3d.
We pulled over, and tried the turn-off/ turn on suggested in manual with no luck- stuck in 4th. I then got the transmission tool out, turned hex counter clockwise a couple times, turned the key now reading 2nd. Shifted into neutral and started it up. After I short ride on the road we proceeded to go up the trail in 4wd, and did a couple hours of riding (1-3 gears) with no problem.
Coming home I noticed as I shifted in 4th and 5th there was a hesitation as it went into gear. Kinda “waaaa-whump” and a jerk as it caught. Got home ok.
Yesterday I took it on a test ride, and it seems worse. A longer lag/ jerk going into 4th and 5th, and some lag/jerk going into 3d. There she sits now.
What happened?
Is there anything I can do at home (clutch adjustment- I’ve not had it in for service since the 500 mile).
If I need to bring to dealer in Bozeman, what $ am I looking at to fix?
It’s a 2017 model.
Thanks.
What happened?
It’s a 2017 model.
Thanks.
