P500 P520 gas tank
The Green Goat
The Green Goat
2,182
16,131
Ohio
It's mildly annoying because there is a ton of extra room under there.
crewcabrob
crewcabrob
1,029
4,039
Omaha
You could for sure have an auxiliary tank on the other side under the driver seat. Pretty much a double the capacity
  • Love
Reactions: hallic and JRF
hallic
hallic
320
1,795
Central MN
Huh. Should still have space for 2nd battery, plus at least a couple gallon mini tank of some kind I'd imagine. That's an interesting idea. Tank, fuel pump, wire in a transfer switch. Either remember to only turn it on when you're near empty, or else plumb in a return overflow line or something.
I freaking *hate* using the new "safety" gas cans, trying to pour into a recessed shin-high gas tank. *adds item onto P5 ToDo list*
Reactions: crewcabrob
Bmurray
Bmurray
438
1,666
Missouri but soon to be Idaho
There's definitely room for one and have a rocker switch to transfer it over or just switch tanks it pumps from. With the right harness it can even feed the 2nd tank fuel level to the display. the other way would just be to connect them together.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
On the surface, I agree there appears to be room to install another gas tank. Before jumping into that space, I would consult with engineers and safety experts before attempting. Point is, there may very well be a good reason why that space is there and not really available for anything else.
The Green Goat
The Green Goat
2,182
16,131
Ohio
Consider me consulted.
Personally, I'd go even more low tech than trying to wire in a transfer pump and fuel sending unit. I'm thinking just an auxiliary tank that's roughly on the same plane as the stock tank, with a transfer hose running from the bottom of it, parallel or slightly sloped downward towards the main tank, then just ran through a bulkhead fitting in the main tank. It would passively fill and drain on its own and your fuel gauge would work perfectly still. Might need to vent the top of it as well.
crewcabrob
crewcabrob
1,029
4,039
Omaha
I've considered mounting one or more Rotopax fuel cells under the drivers seat. I wouldn't need to carry them all of the time. And I like having an idea of how much fuel I have all of the time, meaning I can keep track of the fuel in my gas cans and the tank pretty easy like this.
In reality, I likely only have use for a spare gallon or two once a year. And for those times, I have this Rotopax mounted to the ROPS. Works OK here, but I would love to utilize the space under the seat for something. I hate having wasted storage space.
20211001 223444737 iOS
P
pappyo
597
2,400
IMO - -Iinstalling gasoline storage in the in closed area under the driver seat is - - NOT - - one of the better suggestions on this forum.
The exhaust runs in that area & gets RED hot.
""Suggest removing the roof I you have one""
The slightest leak - - liquid or fumes - - the ejection seat Will Deploy.
Best keep gas storage in Open area Away Form Exhaust.
Using 4 Rotopax ( picture ) only fill them all in winter when using Tracks.
Easier to handle & poor than 1 big container - - plus balance the load.
"" Be SAFE "" FIRST.....
20200725 122406 20200725 122217
crewcabrob
crewcabrob
1,029
4,039
Omaha
Thanks for the suggestion and safety check.
I believe the P520 might have a slightly different exhaust, because if it were that close, I would have never thought about utilizing that area for extra fuel.
Rob
