Is there a simple way to add a turn signal to the rear tail lights of a 2021 Pioneer 520 using the existing lights? I don't need a full kit with front signals. It would be nice to throw a blinker on when travelling together when a turn is coming up.
Thanks
1st. Welcome from central upstate N.Y
Many good people on the Honda forum AND they LIKE PICTURES.
Red was the 1st color all other colors followed Honda hope's they sell.
Now for your question:
Simple YES
NOT USING OEM Lights. ( alot Less time & effort )
Golf Cart Signal Kit includes every you will need <-> $40.00 & up <-> Some INCLUDE 4Way Flasher / Horn & Interxior light options
Mount the lights each corner of ROOF (up out of the way easily Seen <> requires 3/4in. Holes )
Locate & install <-> Switch & Relay
Hookup the - "fused" - Pos & Neg Power feed <-> secure all wires <-> DONE
OEM Honda Roof is easiest
Other hard or soft roofs / Roll Cage <> will work just takes alittle more effort & fabrication to install lights.
Not exactly what you asked for although is Simple /Easy
