P500 P520 Vehicle Recall
G
grease monkey
29
208
illinois
Received a letter from Honda today for an emissions recall on my 2022 P520. Letter states that this vehicle may have an incorrect ECU installed from the factory that is not in emission certification compliance. Seems to start/run just fine. My vehicle build date is January 2022. Anyone else get a recall letter?
68,377
Would you mind posting an image of the letter for us?
G
grease monkey
29
208
illinois
Here's the letter
P520 Recall Notice
68,377
Thanks, We like having these for visibility.
This is the first I have seen of this.
You will have to take it in to get this done.
A good dealer can do it while you wait.
But you may have to request that. lol.
Fatsquatch
Fatsquatch
Approved Member
121,525
1,013,110
Hidden
Is your machine red? Or is it one of the slower colors?
There was a rumor a while back that red machines do get faster ecu’s from the factory. 🤔maybe there was a factory mixup and they let some mismatched ecu’s/colors get out the door? The “emissions” recall is probably just to try to keep that little trade secret “rumor” under wraps. We real Honda fans know that red is the fastest color though.
#RideRed
#NTC
Splorin
320
904
Maine
Always wary of these ‘recall, reflashes’. Hate to get something back home with 10% less power. The diesel Liberty and Jetta owners back in the day were some po’d. The Liberty guys wanted the ‘old’ tune back in it and the dealers wouldn’t do it. The motor was more than the trans could handle was supposedly the issue with those. May not be a big deal. First one to try it will let everyone else know if it sucks. Hopefully they got a ‘red’ tune to keep up with Ol Yella!
P
pappyo
613
2,454
How will Honda ( inspect or repair ) Effect 👉</> Already Adjusted Emissions </>👈
Such as & not linited to:
Opened Air inlet ( K& N Filter /Snorkle)
Opened exhaust ( Baffle </> Removal or Drilling </> Bigger Outlet Tip )
Added </>Power Vision Tuner
Will Honda inspect & repair loose Power Vision Flash </> Requireing repurchase from Power Vision?
No such thing as Errors in Todays Work Force.
Do not take my word for it JUST ASK THEM .
Rdrcr
608
3,288
WA
I hear you!
I too received the recall notification yesterday on my P520.
Mike
G
grease monkey
29
208
illinois
I got a gray P520 (the slowest color), and it speed limits out at the usual 39 mph. Thinking I'm going to wait on taking it in for the ECM update. Reason being, it starts when cold and runs fine. Was wondering if someone else had it done already to see if there was any noticeable difference in start-up or performance.
Only responsible for what they sold you.
P
pappyo
613
2,454
RESPONSIBILITY </> NEVER ENTERED THE EQUASION </>👉 No Blame Game Here
Just wondering if 👉 "Honda's inspect or repair"
Will be Positive or Negative? 👉 Effect on Present Performance?
The Unknown </> unseen </> side effects ???
Most prefer Better & not Setbacks
Better Explanation would Help. </> for better decisions.
The Unknown?
I was referencing your questions on options like a K&N, PV3 etcetera.
They won't do or touch anything unless it involves the recall part and if that messes your tune up, that's not their problem.
Rdrcr
608
3,288
WA
So, I think we need to have some guys pull their ECU’s to check part numbers and post them up for a comparison.
Since my P520 is included in the recall, I’m definitely willing to pull mine.
Mike
Rdrcr
608
3,288
WA
My 2022 ECU Part number (w/ Recall Letter);
AE5B0EAE 4391 4D97 B08B EFF260664A29
grease monkey and my ECU part numbers (#38770-HL5-E62) are the same. Only the UPC codes are different...not sure if that matters.
However, now, we need some brave P520 owners to come forward and share some pictures and/or part #'s of their ECU's for a comparison. By comparing the part numbers of multiple P520's, of all ages, we should be able to see if there is any correlation with the ECU part numbers and perhaps even the units specifically effected by the recall notice. It is possible that all ECU part numbers are the same and it'll come down to the UPC codes? We won't know without further investigation.
I, and I'm sure many others, don't want to electively have their ECU's replaced with another unit that may potentially degrade the performance of the machine. I would like my P520 to have the same or better performance if a replacement is warranted.
Mike
