P700 P700-4 hard start when warmed up
Red Dawg
39
105
Ohio
Hey guys I’m pretty stumped on this one. I just got done doing a lot of work to this 2016 p700-4. ALL new starting gear including cam,torque reducer,one way starter clutch and new oem top end with jug. I also adjusted the valves to spec and the dang thing trashed another starter today. It maybe had 30 starts on it. It was a cheap caltric starter but my thought was that I shouldn’t need an expensive Honda starter with all new stuff. The buggy starts up great when she’s cold. But when she’s warmed up it’s really tough to get her started. The starter seems like it’s struggling to turn the motor over and every once in awhile it would suddenly catch and make a horribley loud “clank” then slowly start turning over again. Now it’s just ground the teeth off the starter. I just ordered the dreaded $427 honda starter which about made me puke when I pushed the order confirmation button. That is a completely ridiculous price I might add. But I’m wondering if maybe the cheap starter just didn’t have enough a** to turn the motor over properly and that’s what caused this issue or could it be something else? I have put a crap ton of time and money into this thing and it’s still not up to par. Pretty disappointed. I’ve rebuilt a lot of atv’s, dirt bikes, and a couple of sxs’s and never once had issues like this. Could it be the computer getting warm, weak fuel pump, tiny battery? Seems like the design of this thing is pretty crappy if you ask me. Any info will help. Thanks!
Red Dawg
39
105
Ohio
Also I feel like they should have just added a bigger battery and starter instead of a torque reducer, and fancy camshaft that fails. But who am I.
Mark in Northern Iowa
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
A quick guess would be the spring is getting weak on the torque reducer.
When hot it is even worse.
But other more knowledgeable will probably chime in to help.
Have a good day
Edit
Crap, didn't see that you had already changed it.
Reactions: Red Dawg
Red Dawg
39
105
Ohio
Yeah it’s all brand new so I’m stumped.
486
2,162
Floyd County, Iowa
ok, now to type CORRECTLY what I read about this morning. Was running late for work.
I had read about the auto decompressor there is small spring that gets weak.
Something to research.
Back to work
Have a good day
Red Dawg
39
105
Ohio
Yeah I read that too. That is located on the camshaft and I put a whole new camshaft in it. So all of the starting gear has been replaced. So I believe it’s either fuel related or computer related.
Reactions: Backwoods
Red Dawg
39
105
Ohio
Idk maybe once I get this fancy gold plated starter in the mail it will start better. 😑
  • Haha
DRZRon1
DRZRon1
1,201
3,877
PA
suggestion if new starter doesn't solve,
check starter solenoid
ive jumped from a car battery direct to the starter on small engines, atvs to eliminate if the issue was starter\battery\solenoid\etc. or a bad decompression mechanism, valves way out of adjustment, etc.
Reactions: Red Dawg
Red Dawg
39
105
Ohio
Wow that’s a great idea! Thanks for the advice!
Red Dawg
39
105
Ohio
Well guys the oem starter made a huge difference. Cranks over way faster than the cheap one. It doesn’t seem to struggle at all also. So it seems to have fixed the problem. Only time will tell. Thanks for the help y’all! I truly appreciate it!
