Talon Paint damage
nm6r
nm6r
78
173
Sandia Park, NM
Here are the results of my paint after washing off some mud.
IMG 20190809 111206 Edit
The dull areas appear on the paint and shiny parts of the graphics. They can barely be felt with my finger nail. I tried a clay bar anyway to no avail.
Any suggestions?
Reactions: CumminsPusher
319,870
The dull areas appear on the paint and shiny parts of the graphics. They cannot be felt but I tried a clay bar anyway to no avail.
Any suggestions?
Not sure I’ve ever seen mud do that kind of damage. That sucks I’m sorry to see that.
You could try a little 1500-2000grt sandpaper and some rubbing compound, short of spraying it would be my only suggestion. If you tried that I’d do an inconspicuous spot to make sure you don’t go through and it polishes up good.
Clay really only helps with something on top of the surface, since that appears to be etched in it doesn’t surprise me it didn’t work well.
dnjones161
dnjones161
583
1,712
Any suggestions?
2nd the sandpaper/polish recommendation.
I didn't realize these were painted. Might be worth it to throw a few coats of nice wax on the whole thing. In a huge fan of Liquid Glass.
It ain't cheap, but it's easy on/off, makes the paint look 3 ft deep and if you get a couple layers on it, it'll last forever.
Reactions: Mudwing and nm6r
nm6r
nm6r
78
173
Sandia Park, NM
Apparently the surface is etched. I tried some swirl remover and it did a respectable job but takes forever. I would never get all the spots removed.
I gave some 1500 wet a try but it's way too aggressive for Honda paint. I should have known better having had japanese motorcycles for many years.
319,870
Was kind of worried about that. Well dang. Must’ve burned all the way in. Wish you were closer I’d just squirt it for ya real quick. Maybe consider some graphic from CreativeUtvGraphics or something
dnjones161
dnjones161
583
1,712
This is just what I was thinking- sounds like a good excuse to do a wrap! That stuff has come a long way- fairly durable and looks sharp now.
Honestly though, 2 miles into the trails a little dust or mud will prolly cover that right up and no one would even notice.
nm6r
nm6r
78
173
Sandia Park, NM
Apparently, Liquid Glass is no more.
nm6r
nm6r
78
173
Sandia Park, NM
I was able to use swirl remover and polish out the effects of the 1500 grit. I know a little dust, dirt or mud will camouflage the imperfections. Maybe even won't show in sunlight. It just kills me and they are all over on every painted panel.
I tried my 10 inch orbital polisher and that sped things up but what a mess and hard to control in small areas. I think I will get a 3 inch polisher and take my time.
This isn't the first time I got it muddy. It cleaned up beautifully with no ill effects. This mud was like big, wet turds that got kicked up from the tires. I just don't understand why this mud had this effect, and how to prevent it from happening again.
nm6r
nm6r
78
173
Sandia Park, NM
Update: I don't know if the surface got etched or it was just a nasty residue that nothing would remove. I picked up a Harbor Freight 3 inch buffer kit and some final polish. That did the trick nicely.
btw, I was using Top Coat F11 for paint protection. Now I am giving Klasse All in One a try.
dnjones161
dnjones161
583
1,712
Let us know how this one works out. I was about to pull the trigger on some f11 for the truck but after seeing this I think I'll hold off
nm6r
nm6r
78
173
Sandia Park, NM
My road and the next road are not paved so it gets dusty. I used to use Klasse on my passenger vehicles but switched to F11 because it repels dust so well and it works on the textured black plastic, windows and interior really well.
This was my first issue of it's kind ever. Time will tell if it happens again.
W
willpower35
6
5
clinton ny
Good to know. I will have to try that next time if it happens again.
Any particular tire shine brand? Spray can? Pump sprayer?
its called reliable silacone tire shine
its called reliable silicone tire shine. just spray it on a rag and wipe the machine off. i use all over the wheeler nothing sticks to it
Reactions: nm6r
ofrcboy
ofrcboy
501
572
Oregon
Google search and can't find "reliable silicone tire shine" more info please or pic of .
nm6r
nm6r
78
173
Sandia Park, NM
I found it...
Reliable Tire Shine 22 oz. Spray
They also sell it by the gallon.
I called them to get info on the product. For example, is it safe to use on a painted surface? Does it contain any petroleum products? Unfortunately, they were of no help. They couldn't answer either question. "it's for tires" was their answer. "We have products to clean and protect painted surfaces."
You can buy directly from them or try to find a dealer.
ofrcboy
ofrcboy
501
572
Oregon
I found it...
Thanks I did finally find it 16oz, 22oz and gallons from Reliable 1, but couldn't find any distributors must have to buy it direct.
