Talon Picked up my Talon X today!!!
1Ron
68
128
Rockies
OK here’s the quote from UTV Guide-the Rock Crawl review:
Low Range – The Talon comes with separate low and high range so coupled with their 6-speed transmission you actually end up with 12 forward gears. The separate high/low has a ratio of 1:1.4 and in my opinion Honda could have made that much lower since there are 6 total gears to choose from. I want low range to span from super slow speed technical rock crawling to about 30MPH tops. 53MPH top speed in low range is pretty silly.
I believe that top speed is limited by a governor....
Dwight
27
Kansas
Yeah, I saw that speed quoted after reading through their review. I'm also disappointed in the low gear ratio. With a 53mph speed in low range and with the type of riding we do the selector lever may rust in place! I want to like this buggy but am concerned that we may see some of the clutch problems that the Yamaha yxz and the 1000 Pioneer suffered. Crawling is a big part of what we do and 30" tires are pretty standard which will add to the gearing problem. Wouldn't it be great if there was a simple and cheap way re-gear low range? Maybe it will all work as is, it's probably worth waiting for some real world input before I make any decisions.
Dwight
1Ron
68
128
Rockies
I think it will work fine for 30’s but will try my 32’s first. I’m presently running almost new 10 ply Kanati Terra Masters. Each inch is about 4% taller gearing so 32’s make low range almost like high for most riding. Top speed now almost 60. That might be OK if lower gears are still low. With my CVT I run low range except for flat trails or roads and have to hit rock ledges with momentum to avoid burning the belt. The only way to know is going to be by trying it. Heavier 32’s will also change unsprung weight and might require shock tuning.
One good thing is that (in theory) it should be easier to gear the transfer case vs the transmission.
DaveM47
DaveM47
26
104
Helena MT
Yes. I'm working on a review. But I dont have a team like some of these other groups. Goal is mid week.
I cant wait to hear back from you, i should have my X in a couple weeks i hope, let me know how loud the engine is, can you converse with a passenger without screaming and such. The CanAm i had was so loud you had to scream and wear ear plugs. Good Luck and don't make everyone here what to long LOL
Talonpalooza
Talonpalooza
122
237
One of the reviewers at Sand Hollow said you could have a conversation without raising voice.
Russ989
Russ989
22,642
147,257
HondaTech
I'd assume its similar to a P1K, maybe better since the engine is more open and further back in the chassis.
Caper
Caper
7,801
11,030
Halifax Nova Scotia
WillyBill
WillyBill
Wheeling Addict
479
1,904
Clinton, Utah
  1. Talon X LV
Shelly
185
513
Congrats on the new talon. I have been looking at them hard. I have a 2017 1000-5LE. It is perfect for what I need right now but in a couple of years it will not be perfect for what I need.
swampsnake
florida
Congratz on yer new toy! You've managed to make Alot of us lil boys very envious! Next pix better have our other favorite colour MUD!! Ride safe & enjoy..
Vondy
Vondy
1,550
10,270
Houston,OH
  1. Talon X4
Congrats, Sure are making the wait difficult on some of us!
Reactions: sharp
