Pics without warning plaque?
No1hedberg
No1hedberg
15
Does anyone have any pictures of the P700 dash with the warning plaque removed. Since I bought my pioneer, I have a million ideas going through my head about lights, stereos, and switches for that spot. Just not quite ready to start cutting on my new SXS without knowing what's under there. Thanks.
322,690
There is a metal brace under there (under the third switch from the left on top row) so the switches were a little tricky but the stereo went easy it's one of the only ones I could find to go in that was water resistant but had to be on far left. I used the plastic from a cheapy tool case to get same type of texture as factory and sprayed it semi-gloss to match color. Everything was easy to get to. Nicer then looking at a don't do sticker
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Kinda a bad picture but you get the idea. I just peeled the lawyer plate off, used it as a template to cut out the aluminum sheet, and this is the result. Definitely check behind the plate before you drill for switches, my winch switch on the left barely clears on the backside.
Farmer
Farmer
2,916
16,789
Southern MO
Keep reading and searching. There are probably a few thousand posts out there full of ideas on this subject. Then come back and post your pics for everybody to see! ;)
No1hedberg
No1hedberg
15
Thanks for the replies guys. I was hoping someone had a pic to show whats back there. How far behind the metal brace behind the warning label, approximately? If the those switches are really close to it, can't be more that an inch or two I guess.
322,690
You are correct. But that gives you idea where it's at. The rest is pretty open. The brace runs pretty much straight down if I remember right. Right side is clear
