2018 pioneer 1000 wont start. constant rapid dash flashing on gear indicator , new battery, new neutral safety sw.
4 yrs and first post!2018 pioneer 1000 wont start.
Also, need more info…2018 pioneer 1000 wont start
2160 miles. Yea did the clutchrelearn,, constant fast flashing dash. Hello Honda flashing also. Have counted 80 fast flashes no long flash..all fuses good. Don’t hear fuel pump. I work nights so might be a while before I get back. Will get pics when I canAlso, need more info…
how many miles?
First owner?
Clutch update done?
Have you done a clutch relearn after u did the switch?
Thanks
When you first turn the key and the display is doing its Hello Honda startup you should hear the fuel pump pressurize for a second or so.Those two grn didn’t help. Seams more electronic too me. Should you here the fuel pump runnin with key on. I don’t remember. Bought unit new in 2000 even thou it was a 18.
Or critters?Well finally took it to Honda shop. They tried a ECM. No help. Now there saying chaffed wiring harness ..
