Pioneer 700, no spark
DRZRon1
DRZRon1
1,434
4,392
PA
The 3 stator wires have nothing to do with spark, only charging.
The other 2 wires coming from the stator are the pulse generator or pickup coil. They tell the coil when to fire.
@kentuckypioneer
Have you checked the stator wiring to verify it hasn't been damaged by debris, also make sure the connections are tight.
thanks - I wasn't sure if the stator helped the system when firing - so I stand educated!!!
Reactions: Backwoods and TxDoc
Hello_Darkness
Hello_Darkness
666
2,678
Just to the right of nowhere
Common misconception
The 3 stator wires (yellow) output AC voltage in pairs that can be measured to verify each leg output is even and not dead if a charging issue appears to exist.
The pulse generator should pulse atleast. 7v DC, but there always higher. You need a peak voltage tester or an ignitionmate analyzer. A digital multimeter can't catch the pulse fast enough
