Pioneer dump bed frame caps! UPDATED!!!
68,420
10spoke
32
6
Re: Pioneer dump bed frame caps! R U interested?
I'm in for a set.
fishin2Dmax
fishin2Dmax
186
32
I'm also in for a set.
N
nagromr1
66
I'm in for a set.Didn'tknow they were that many.
TandT
TandT
357
22
Newark, Ohio
I'm in just let us all know.
68,420
All right.... I'll get more info out this weekend.
Thanks.
daberry
68
0
Kansas
I'll take a set. Dale
I
idahohntr
141
5
0
Count me in for a set- if I was home I would help with the 700 2 inquiry. Be back in a few days, if no one chimes in on the request I will!
Thank you
ryan4703
ryan4703
5
0
I'm in for a set.
bdech15
bdech15
0
www.facebook.com
In your fourth picture are you doing a cap for the small square tube as well? Left of the larger cap in pic?
68,420
Working on it. And the round tubes in the frame just behind the wheel.
tiogajoe
48
55
Yes. Im in!
I'm in for a set.
Clarky
108
Count me in. It seems odd that Honda would have left so many open ended tubes. I am already seeing a little rust in them.
W
waterboy1
10
0
I will take a set
sksshooter
79
are you guys sure plugging these tubes is the right thing to do? these plugs aren't water tight and it would seem that trapping moisture inside the tube would be more likely to cause rust than an open tube that would dry out between wettings.
fishin2Dmax
fishin2Dmax
186
32
Yes, you're correct, if moisture is allowed to builds up in the inside of tubes, it will rust. I plan to use a marine sealant when installing the plugs to make them water tight; keeping the moisture out is the better option.
sksshooter
79
are you planning to apply some type of rust converter inside the tubes before you seal them up? I know mine already have some minor rust inside of them. just sealing them won't stop the rust and I would almost bet that the change in temps will cause moisture to build up inside of the tubes. my experience from working in a fab shop for a bit and then 10 yrs in chem plants the only way to really keep the inside of a pipe/tube from rusting is to keep it under a constant n2 purge to keep both moisture and oxygen out.
bigc
bigc
432
128
i just went out and looked at my 2 seater the only ones that are open are the 2 beside the receiver hitch 4 on the front of the bed frame and the round ones on the front end as shown here so the 4 seater must have alot more
