P1000 Pioneer storage
G
GWH
748
2,475
Las Vegas Nevads
Just wanted to thank you guys for that great idea,door underseat ,ordered mine Wednesday and installed this morning.Thanx again !
G
GWH
748
2,475
Las Vegas Nevads
All I can say is for u guys that drink beer and go for it ,is take the seat off and ruber heat shield away ,and realize the ECM is there!
G
GWH
748
2,475
Las Vegas Nevads
A saws all w a 12” blade might get u in trouble! Who’s gonna win ? The supper bowl?
G
GWH
748
2,475
Las Vegas Nevads
Thanx kilo! How the hell u found the perfect size door!,,l
G
GWH
748
2,475
Las Vegas Nevads
Hmmmm it’s half time ,Shakiraa that’s a lotta ass shaking!gotta say ....Like it!,,
61,543
How much did you have to alter the door frame to make this fit? Seems like at 9" wide there's not enough room. Thanks in advance.
You don't have to cut anything off the door if you don't want to, it will just hang over the edge where the warning label is indented. I didn't want to risk getting in, catching something on it, and then ripping the door off so I modified mine. I cut about a 1/2" off the side with the hinge so it would sit flush with the edge of that warning indention:
1581446784235
1581447249156
If you don't cut anything at all, it still goes in fine but you'll have some overlap like this:
1581446872938
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,866
Oshkosh, Wi
I cut mine similar to Adam. I cut from the backside of the frame down the center of the inner groove. I then ground it flush with the inside edge of the groove.
IMG 20200202 101216
G
grizzly660fan
50
86
I am about to do this modification. Do any of you have any pictures of the hole before the door is installed I can use as a reference? Trying to figure out how to cut the hole is my only challenge.
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,866
Oshkosh, Wi
Cut along the bend radius on the inside and down the center of the plastic push pins on the driver door side.
Reactions: JTW and Isaiah
