Pioneer Suspension Adjustment
A
atv
20
  1. Big Red
The Pioneer utilizes a hydraulic damping, spring shock system that suspends the weight of the passengers, cargo, and the Honda Side by Side correctly. The oil damper system hydraulically controls the natural compression and rebound of the suspension springs so that comfort and traction are well maintained as the terrain changes.
Front
The front suspension consists of a double wish bone, standard shock offering 7.9 inches of travel. It set to provide the right cushion amount for heavy loads and tough terrain.
Rear
The rear suspension consists of a double wish bone, with a pre-load shock capable of 5 different adjustments. A lower pre-load provides a softer ride and is the recommended choice for light loads and smooth terrain. The higher spring pre-load provides a firmer ride and is the recommended choice for heavy loads and rough terrain.
Position Settings:
Position 1: for smooth terrain and a light load.
Position 2: for normal every day terrain. The standard position from Honda.
Position 3: for a medium load or medium terrain.
Position 4: for a heavy load or rough terrain.
Position 5: for a full load or very rough terrain.
It is recommended that both shocks be adjusted equally even if the load such only a single passenger in he rear.
Adjusting the rear suspension.
The rear pre-load is only adjustable with a compatible spanner wrench offered by your Honda dealer. Use Honda part number 07702-0020001 available at your local dealer. Honda recommends that adjustment is made equally even if the load such only a single passenger in the rear seats. To adjust jack the rear off the ground. Use the spanner wrench to turn both shocks 1 notch at a time until the desired pre-load setting is reached. Do not quickly jump from setting 1 to 5.
Following this direction will allow for a comfortable ride for you and your passengers.
N
nutmeg
30
This is good info. I will need to learn how to adjust mine. Where can you get that tool from?
T
TrailTamer
Does it have the adjustable shocks on both the front and rear?
43,046
No.
Only the rears are adjustable.
Melikiehonduh
39
20
Will an universal spanner wrench or does it have to be the $99 honda one?
66,863
Universal will work most of the time. I have had luck with a large pair of channel lock pliers also. But I only went one notch. Be careful not to strip it.
hurld
hurld
129
159
Easy to do with channel lock pliers, just make sure you jack the rear of the machine off the ground so it turns easier.
digbydog
19
Downeast Maine
Does anyone know what size the rings are on the shocks? I see a wrench that will fit 87mm and 68 mm rings for $37 on eBay, just want to know this will fit......sure beats the $100+ Honda part.....
BustedKnuckles
BustedKnuckles
6
Jacobsburg,OHIO
Front
Rear
Position Settings:
On my 16 1000-5. Can I adjustvrear shocks? I flint see any kind of adjustment?
Redrider700
Rossville, Georgia
Just a quick question guys what is a good setting for having 2 adults in the back setting 4 or 5 and what's your exsperiance with your setting?
