Assuming it is still not running, I would check fuses, then pull the air filter and spark plug. For the air filter, check to make sure you are not wet there and with the plug out, spin it over a few times and verify it is firing off. Next, I would put in a new plug. Finally listen to ensure the fuel pump is coming on the moment you turn on the key.
