I just bought the machine and this is the list of things I’ve done so far (maintenance and upgrades).
After getting the machine back from servicing I noticed a decent amount of coolant from the bleed valve had run out and down the hose. I began installing the new parts (about 7 days from service to finishing the installs) I installed the light bar and cubes power direct to the battery. (Switches are always powered when ignition is off, I know, but I always start it every day and move it around) Took it out for a ride and noticed a plastic burning smell in the cab. Thought it was the 50 watt led headlights so I removed and replaced with the oem 35 watt halogen. Smelling around and couldn’t find a source. Took it out again today, 10 minute ride, noticed the smell again. I looked around, smelled around the battery box thinking my wiring job was causing it, no distinct smell in that area which I did smell in the cab. Removed the seat and faintly smelled the plastic smell.
Got under the machine and noticed coolant coming front the top of the hose where it attaches to the elbow which the bleed valve is attached. The coolant was running down (single drop line all the down) where it is circled in the picture. *The picture was taken 2 hours later and had dried up to where you see it now*
Smell goes away when off. The “plastic” burning smell is only in the cab area, under the machine smells like coolant. Could it be one in the same? Thanks
Search results
hondasxs.com
