P500 Plastic for ( DIY ) MUD Guards & ???
P
pappyo
613
2,454
Online at :
SpeedwayMotors.com
Airdam/Body extention Plastic
1/8in Thick x 22in. Wide x 25ft. Long roll. SMOOTH texture
Black was under $75.00 shipped to door ( guarantees 2 Day Del. )
Other Colors & lengths available.( $$$$ varies)
Durable & Flexable -- stiff enough to hold desired shape using a heat gun.
Easy to work with -- Heat Gun -- tin snips & or sabersaw.
Only your imagination & fabricaton skills is holding you back.
Mud Guards
Fender Flair's
P520 Box area above & in front of Rear Tires (prevent mud build-up up )
P500 Floor protcctors ( P700 too )
Unlimited uses! Atv/UTV-- trailer -- Truck
LESS -- $$$$ than 1 set flairs or mud guards
20220304 144024 20220304 144414
Maine Farmer
10
44
ME
Thanks for the idea! Used a roll to make a set of 3“ rear inner fender extensions and a set of full front fender and inner wheel well shields for my P500. You can see the layer of cow “poop” built up on the inner fenders.
12DD3809 CFDB 4E74 871C 526A23CEA067
P
pappyo
613
2,454
Nice!
Now that you have it you'll find many uses.
Original reason for purchase:
Needed to fill space Above & Below Rear Hard Panel ( with Slide Open window ) making at the time for 2022 P520
Pictures of rear panel.
Thanks for the idea! Used a roll to make a set of 3“ rear inner fender extensions and a set of full front fender and inner wheel well shields for my P500. You can see the layer of cow “poop” built up on the inner fenders. View attachment 353508
Have since :: coverd the under side of P520 dump box >< keep snow & mud out ( space between box & outer panel )
20220407 093231 20220407 093056
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I have some 1/8" plastic purchased years ago, when I added 1" spacers. Never installed though. Now running with rims that added about another 1" +- so, need to add the front fender flares. I'd be interested in how you mounted yours. I'm thinking a couple of muffler clamps on the frame tubing, along with the plastic plugs.
Reactions: Mudder
Maine Farmer
10
44
ME
Sorry right in the middle of wrapping up the last of haying for the season, once things slow down I will do a decent post or video. I cut the plastic and heated it so it covered the usual mud flap portion and also folded over and covered all the holes twords the radiator under hood area. It came out nice.
Reactions: alrewe20 and futzin
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Look forward to the pictures/video.
Around here, 1st cutting was good, 2nd was poor (too dry), and last cutting improved with late summer rains, but now the drying time is always a challenge.
