P500 Play in steering wheel
wvupsc
wvupsc
180
802
West Virginia
I've noticed that on my 520 that there is play in the steering wheel. Not the shaft but the actual plastic steering wheel assembly. It slides in/out about 1 inch. The shaft it's attached to doesn't move. Is that normal, or is there an issue with the steering wheel assembly?
RRogers
RRogers
35
107
Not sure on the 520 but my 500 is rock solid
Look under the hood and make sure all the linkage is in proper order I’m thinking you should not have any play in the steering rack
You might also pull the steering wheel cap and make sure that nut is tight as well
The Green Goat
The Green Goat
2,116
15,566
Ohio
This. The clamping bolt rides in a slot on the splined shaft. One of them probably isn't tight enough.
Reactions: wvupsc
wvupsc
wvupsc
180
802
West Virginia
Thanks. I will give that a look. Seems like Honda QA/QC has some issues with the 520s from what I've read on here.
Reactions: Fischer
The Green Goat
The Green Goat
2,116
15,566
Ohio
Yep...that was it. I popped off that plastic center cap and tightened down the nut. Fixed a problem that should not have been for a unit with less than 10 miles on it.
If it was the steering wheel nut, that's a dealer-installed item, I believe.
Reactions: wvupsc and trigger
Robertb52
Robertb52
68
191
I had the exact same thing when I brought my home. The nut securing the steering wheel on the shaft was only hand tight; nylon thread lock not even engaged.
I don’t know if its dealer installed. I made that point and one of the forum members (can’t remember name off top of my head) works for honda said it was; but I can’t help but now think otherwise. That is, unless you bought yours from Honda of Salt Lake City. :oops:
Jerryg
Jerryg
11,961
94,949
NEPA
It was the same with the Honda lawn tractors in the 80's and 90's.
Put the steering wheel on straight, tighten and pop the cap on,
Not rocket science.
Maybe Honda will start selling UTV's in Home Depot like they did with the Power Equipment.
Reactions: Fischer
wvupsc
wvupsc
180
802
West Virginia
Mine was purchased in WV.
Mudder
Mudder
NTC Ambassador of Walls
11,607
87,392
I would share that with Dealer and Honda Corp. Dealer error could have ended bad on the trails. Seems like so many issues lately.
