Pulling the little hair i have left
116,574
@DG Rider is good with P7’s maybe he knows how to pull up past codes on them?
Reactions: DG Rider and TxDoc
116,574
@Eganmancan the search pulled up this if u want to test it.
Also, did u ever load test that battery?
Reactions: TxDoc
Mudwisel
Mudwisel
10,175
84,043
Tampa Bay Florida
Things to check . As state above. All grounds. Check to make sure your stator is working properly. You said you already replace injector and fuel pump. Also when it is about to die will putting it in neutral stop it from dying? Someone I know with a 17 was having same issues and had it at dealer twice and they changed same items as you. I suggested he have them check his stator the third time and they kinda smirked at that. Guess what it turned out to be . Stator
Reactions: TxDoc
E
Eganmancan
9
29
Lafayette
I will check harness thoroughly tomorrow.and the staror When it dies out its like i turned the switch off. It doesn't run bad or rough.
Reactions: TxDoc
Hello_Darkness
Hello_Darkness
679
2,757
Just to the right of nowhere
not related but I have an 02 rubicon/foreman 500 from my buddy that I have about 30 hours into trying to make a spark - cleaned grounds\ecm board, etc. and down to pushing pins through each end of the wires to check for continuity through connectors, digital display is dead but oil\neutral lite all work p have good peak voltage from crank trigger, neutral switch, tested stator, etc. bad news is the CDI is built into ECM - trying to convince myself its not the ECM but running out of things to clean\check\verify - there is a new VR installed but my moron buddy has 2 more to drop off and cant remember which one was which and if any were bad - lol :(.
it never ends
Apologize for the delay in response, I'm digging
116,574
I posted the procedure years ago on the 700 section. Someone else posted it above.
Sounds very much like a CKP thing, which is built into the stator.
Thanks for helping out.
I wanted to make sure he went through the basics before indulging in big expensive stuff.
