BOX1
pv3
MDFMac
135
240
upstate ny
i have a 2020 2 seat i purchased a pv3 to start messing with my tune. but the pv3 wont pair with the stock machine. it says no compatible stock file. it has every file dynojet has on its site for the talon. not sure what to do when i cant talk to them till monday. did a search online but cant find any thing that is the same.
62,637
You didn't buy a used one, did you?
I had a problem too. but it was because I erased my stock tune.
Once I loaded it from DJ it worked.
PaulF
PaulF
1,462
4,805
If I remember correctly, you have the Jackson Turbo. If that is the case, I don't think the PV3 is compatible with turbo ecm flash and I don't know if Dynojet is working on that or not. You will have to contact them.
MDFMac
135
240
upstate ny
i have a stock ecm. and a brand new pv3 from dynojet i purchased a new ecm to start experimenting with. they cost less than the pv3
PaulF
PaulF
1,462
4,805
OK, that makes sense.
There should be a PV_INFO file on the PV3, if it is missing, the PV3 has not paired to the ECU. If it is there, look at the PV_INFO file and see if it "paired" correctly to the ECU. It should look something like this (some items will be blank)...
Device Information:
FW Version: 5.4
FW Build: 7167.19235
Serial: PV00040986
GUID: 04019005-c0c6-ab1b-ad3f-9b5bc50700f5
Paired: 1
Pair Version: 2
Paired ECU: 55394FC1F939CD19
Paired Vehicle: 496EFB6530D6C4BC
Paired Tune Compat: 0801EB0402
Paired Checksum Compat:
Version: 1
Vehicle Model:
ECU Model:
ECU SN: 55394FC1F939CD19
ECU VIN: 496EFB6530D6C4BC
ECU Manu PN:
Veh Manu PN:
ECU Tune Compat: 0801EB0402
ECU SW Version ID:
ECU Patch Num:
ECU Checksum:
Ignore Checksum: 0
MDFMac
135
240
upstate ny
nope not paired all entries are empty for the vehicle
PaulF
PaulF
1,462
4,805
Well that's not promising. Try this...
Attach the PV3 to your PC and delete all the files (even the PV_INFO) or do a reformat form the menu...
Device Tools>Reformat Disk
Then plug it back in, turn on the key and let it generate a new PV_INFO and see if it is still blank.
MDFMac
135
240
upstate ny
hmm very weird formated... hooked up and here is the file.. just says no compatible tune. now i know the jackson tune was on this ecm before. i wonder if when i put it back to stock jackson has some residual stuff on there that the pv3 doesnt like
Device Information:
FW Version: 5.12
FW Build: 7710.34180
Serial: PV00075023
GUID: 0601d038-7406-ab7d-4f0e-1c5fc00700f5
PV3 Recovery State: 0
Paired: 0
Pair Version:
Paired ECU:
Paired Vehicle:
Paired Tune Compat:
Version: 1
Vehicle Model:
Model Code:
ECU SN:
ECU VIN:
ECU Manu PN:
Veh Manu PN:
ECU Tune Compat: 0801EB0401
ECU SW Version ID:
ECU Patch Num:
ECU Checksum:
Ignore Checksum: 1
MDFMac
135
240
upstate ny
i noticed your firmware is newer. cant find one newer than the one i have tho
PaulF
PaulF
1,462
4,805
Yes, that PV_INFO I pasted was old. I think your PV3 is up to date.
You should be using the 1603002 stock tune and matching 1603102 and 1603104 custom tunes. If you don't have those, you will need to log into DJ and submit your PV_INFO file so you can download them.
If you have them, upload the stock 1603002 file ONLY, attach to machine and see what it says.
Post exactly what the screen says, it should say either "No Compatible Stock Files" or "No Compatible Tune Files".
PaulF
PaulF
1,462
4,805
I misread that. Numerically, 5.12 is less than 5.4 but 5.12 in versioning is actually higher than 5.4. You have to break it down at each decimal. the 5's are the same but 12 is greater than 4. Like Season 5, episode 12 (if that helps make sense of it).
You have the highest version that I am aware of.
PaulF
PaulF
1,462
4,805
Then it looks like flashing the Jackson tune and then back to stock doesn't really put it back to stock.
DJ will probably be of no help but you can try. Make sure and tell them what that ECU has been through. Maybe they have a trick to get the PV3 paired somehow.
PaulF
PaulF
1,462
4,805
NP. Sometimes 2 heads are better than one but not this time :)
MDFMac
135
240
upstate ny
so i call dj today and they were pretty quick after i sent them my info file they saw the problem with the ecu that i have that was still modified by jackson even tho it was put back to stock. so they modified a firmware update for me to make it work. i have not had a chance to try it yet but i will tomorrow after work. got to say so far very happy with the customer service with them.
BOX2
box3
