Question on oem switch plate.
rogerdodger
rogerdodger
29
I have a 2014 Pioneer 700 SXS with the factory add on switch panel and the factory add on fuse box. I have a set of Led lights that I would like to mount in the front and in the back. Does anyone know what kind of plug I need to obtain to plug into the back of the honda fusebox? Without using a honda $100 factory wiring harness from the light to the fusebox. Thank you!!!
67,230
Re: Question on fusebox plug
Welcome to the Honda SxS Club!
Here you go.
You can buy them here.
2 pin - http://www.mouser.com/ProductDetail/Mol ... pMng%3d%3d
3 pin - http://www.mouser.com/ProductDetail/Mol ... 2bag%3d%3d
4 pin - http://www.mouser.com/ProductDetail/Mol ... yIhg%3d%3d
You also need the pins. I highly recommend ordering extra cause there easy to mess up.
http://www.mouser.com/ProductDetail/Mol ... 04snrDQ%3d
You can get plain switches from about anywhere. But here you can get custom ones - http://www.otrattw.net/Contura-V-SR/
rogerdodger
rogerdodger
29
I'm plugging into auxiliary lights. One for the forward facing led's and one for the rear facing led's. Do you know if I need the 2, 3, or 4 plug? Thanks.
