Talon RB3 Wheel spacers
7,144
27,184
Got a set of wheel spacers from RB3 a week or so back. Finally got them installed and tested.
20190622 122016
1st thing is these are very high quality in fit and finish.
20190625 185240
I installed 1 1/2" on front and 1" on rear,
20190625 185137
This made the front and rear very close to being the same width. They include the lug nuts needed to install the spacers.
20190524 171158
20190524 171414
I have seen others have trouble with the wheel contacting the original wheel studs with spacers installed. The picture shows they do not have this problem.
20190524 171121
These should allow for many more choices when its time for new wheels and tires.
RB3offroad
RB3offroad
1,704
4,768
Tempe, AZ
Thank You!
Reactions: Tramguage1
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
So the talon doesnt have the same offset as the pioneer?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Not sure, guess I should measure
Well you said you put the fatter spacers on front. On the pioneer it needs the bigger spacer on back....
RB3offroad
RB3offroad
1,704
4,768
Tempe, AZ
Suspension/
Brakes
Front Suspension
Independent double-wishbone; 17.7 inches of travel
Rear Suspension
4+ link trailing arm; 20.1 inches of travel
Front Tires
28 x 9-15
Rear Tires
28 x 11-15
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
NO see below comment
Suspension/
Brakes
Front Suspension
Rear Suspension
Front Tires
28 x 9-15
Rear Tires
28 x 11-15
What matters is the factory wheel offset and measurement from hub face to hub face. That is why on a pioneer 1000 when people switch to a 5+2 rim all around they need 1inch spacer on rear and 0 in front....or 2" rear and 1" front. Just wanting to clarify if the talon is the same scenario or different.
7,144
27,184
I'll have to verify all the measurements
Reactions: Cuoutdoors
