Got a set of shocks lined up. So may be a 700 shock upgrade demonstration going on at the [HASHTAG]#takeover[/HASHTAG]
Does the p1000 shocks ride better than your stock? Once you get them installed let us know! Also did you get 3 inches of lift?Got a set of shocks lined up. So may be a 700 shock upgrade demonstration going on at the [HASHTAG]#takeover[/HASHTAG]
Got ya. Does your 1000 ride better than your stock 700? If I could find a cheaper seat of 1000 shocks I'd test it out and write up a review.I don't own a 700 anymore, i did do the Commander shocks on mine when i still had it. It was the second best thing i did to it. Power steering was #1.I'm going to try this on a buddies 700-4. I still have not found anyone that has done this swap. I
Oh hell yes, but I have the LE with stock Fox's.Got ya. Does your 1000 ride better than your stock 700? If I could find a cheaper seat of 1000 shocks I'd test it out and write up a review.
I havnt done a whole lot of research on the self leveling shocks but how do they work ? It seems like the # would be to stiff for the 700.Got a set for sale for $250 links in post number 9.
unfortunately we will not be there this year.Coming to the [HASHTAG]#takeover[/HASHTAG] ?
The rears off the 1000s are to big in circumference to fit the 700.I havnt done a whole lot of research on the self leveling shocks but how do they work ? It seems like the # would be to stiff for the 700.
Yes that's how we did it.So someone would need 4 front shocks for this mod?
How much lift did you get front and back? Also how was the ride compared to stock ?Me and a friend both have 1000s and upgraded our shocks. So with 4 front shock laying around decided to see how they would do on my brother in laws 700. Like stated the rears went on with no modification. The fronts however we had to grind down the bushing to fit into the front mounts and with a set of spacers from RB3 everything went right together.
Also got a set of RB3 Wheel spacers to run the 1000s wheels. The setup seems great can't give any good feedback on performance yet but hopefully soon!
3 inch lift in back.How much lift did you get front and back? Also how was the ride compared to stock ?
No the rear shocks off the 1000 are to big. There were clearance issues.So the rear shocks will not work
I never really thought to check that configuration. I'd have to do measuring to answer that.What if you swap put rear shocks on the front front on the rear I don’t want to buy the whole set and be stuck with two shocks I can’t use
