P1000 RC MLC-6 For Accessories
sek-hunter
sek-hunter
317
617
Anyone have any personal experience with this product. Looks like a way to make a simple clean install of a switched/fused/relayed system for accessories.
Pros / Cons vs. building one yourself?
Amre2me2
Amre2me2
381
1,423
Colorado
Only down side I see is that it’s about 5 times more expensive then if you built it yourself.
sek-hunter
sek-hunter
317
617
I thought it was high at first, but six good switches will cost you $90. Amazon fuse box is $20. Switch panel is at least $30. $10 for cables to hook the switch panel to the battery. That’s $150 before you buy any wires, relays, connectors, heat shrink, tape, etc. I’d say the price pretty comparable between the two and you get a simple to install clean set up that is plug and play and simple to add accessories to.
I like to build and figure things out myself. But this has got my attention. Never seen anyone on here use this system in the pioneer. They make a system specific for the Talon. Maybe someone with some experience will chime in.
