Re-gearing the Talon
McCarthy
267
537
Canada
I'm in the process of deciding which tire i'm going to order for my Talon, i'm going to do a 30x10x15, however I do not want to lose power, the Talon doesn't really have enough as it is. With a Jeep I had years ago, I put 37's on it, and regeared it to 4.56's, and that solved my power issue, and got RPM's back to stock +/- 200rpm on the highway. Is it possible to do something similar on the Talon?
SLOWPOKE693
SLOWPOKE693
1,600
6,051
Somewhere in Texas
Not without spending a ton of money on portals or the unobtanium IGR thingy. Nobody makes aftermarket ring and pinions for these things like they do for automotive apps.
This is the only drawback of the Honda trans vs belt. With a belt car you can just change the weights and springs to get where you need to be with larger tires. Not so much on the talon...
McCarthy
267
537
Canada
Yeah I kinda figured. Portals won't survive what I do (nor do I want the lift in any way) and the IGR thing seems way over complicated. Was just hoping for a different ring and pinion.
Reactions: JenElio
BigOL3
BigOL3
2,994
8,918
I wonder WHY some knowledgeable person/business has not made replacement ring/pinions. Seems there would be a good market for them?
No, you drop it off, they put it in, you pick it up and go ride and you’ve got a good 30% reduction and the climbing gearing that you need….👍😎
Reactions: TripleB and JenElio
McCarthy
267
537
Canada
Anyone smart enough to calculate stock machine, stock tires, and IGR and 30's and see how they compare?
Reactions: JenElio
Reduction Boss may be the ones….🤔
Robobrainiac
Robobrainiac
2,458
8,564
I wish someone made ring and pinions for the pioneers and talons. I wouldn't mind it if they were loud even. I think rings and pinions would be easy
Reactions: McCarthy
5,026
22,456
I'd like those numbers for 32's too. If I'm going to the expense of IGR, I'd just as soon step up to 32's since I'm satisfied with the way mine runs on 30's now.
In other words: what IGR ratio would I need to end up with stock gearing (on 28's) with 32's.
The IGR would have to be low range only, I don't want to lower high range.
Reactions: IDIOT and McCarthy
41,771
I think the reason no one makes ring and pinions is simply a matter of cost vs sales.
Cars/trucks generally have axles provided by a supplier, and such axle is generally designed to accommodate a wide range of gearing choices for different manufacturers needs. An example would be a DANA 44, which has been available with gearing all the way from 3: something to well into the 5's with old jeeps. Maybe even further in each direction.
The carrier handles the breaks (changes in thickness needed for different gearing set ups), but the housing stays the same.
Now take something like my 700 and most any atv diff I've seen, and the internals have very little room to grow. In short, you'd probably need a whole new diff housing and all the money involved in making it to make significant changes, while still fitting it into the existing space.
PaulF
PaulF
1,462
4,810
30" tires will turn about 7% slower than 28's
32" tires will turn about 14% slower than 28's
However, it's not just the gearing difference that causes the power loss. Stock Talon wheels and tires are pretty light and the additional rotating mass that come with most "better than stock" tires and wheels is also contributing to the equation. So if you put 30's on and 7% reduction or 32's and 14% reduction and they weigh more than stock, you will still feel a power loss, especially in the higher gears.
The suggested compensation is to go about ~50% more reduction to make up for the additional rotating mass. So for 30's, 15% gear reduction (the minimum I think you will find) is recommended. For 32's, 20-25% reductions is recommended.
You may hit the rev limiter before the speed limiter lose some top speed with 15% and you will most definitely hit the rev limiter before the speed limiter with 25% reduction.
Modifying the ring/pinion would throw to much stuff off. The speed sensors expect to see certain things and would probably freak out.
