P1000 Rear Cargo Storage
H2oFowler
H2oFowler
40
89
Memphis,tn
IMG 0429
IMG 0430
IMG 0431
Just thought I'd share an inexpensive cargo carrier I installed today. Picked up both the dual hitch mount and atv cargo carrier at Harbor Freight (20% coupon of course) for around $65 bucks.
Gives me ability to tow trailer and carry more junk when needed. Bed still dumps with no interference.
322,675
View attachment 44190 View attachment 44191 View attachment 44192 Just thought I'd share an inexpensive cargo carrier I installed today. Picked up both the dual hitch mount and atv cargo carrier at Harbor Freight (20% coupon of course) for around $65 bucks.
That looks good especially higher. We had close to that setup and works great. One word of caution try not to overload the rack because even though the receiver is rated at a couple hundred pounds it's meant to be more straight down weight from the tongue of a trailer. A basket further out with the same amount of weight probably doubles that because of the pendulum effect. The receiver isn't the most solid part of the Pioneer.
Reactions: elkguide
H2oFowler
H2oFowler
40
89
Memphis,tn
Makes perfect sense and I appreciate it.
Don't plan on carrying more than coolers, 14 gallon sprayer and hunting gear on occasion.
Thanks!
Reactions: CumminsPusher
322,675
Thanks!
Well it should do that just fine. Just didn't want that receiver to be an issue for you
Reactions: Nipper
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I like that! Alot easier to mount than my XL bed extender lol. Sometimes quick install is the way to go.
Reactions: Tigermark
N
Nipper
84
136
Oklahoma
Put my rack together yesterday. Need the dual mount to extend out far enough that the tube dosent hit the muffler shield then ill be in business. Im sure the stuff on the rack might take a beating from rocks/mud but that will give the yeti some character
Sent from my SAMSUNG-SM-G930A using Tapatalk
I bought a rack from academy a few weeks ago. I need to get a hitch extension like yours! Do you remover how much it was?
N
Nipper
84
136
Oklahoma
Prob cheaper at Harbor Freight but my phone was closer.....5d7a3d3a65a1df86088f9f04169361ff
Reactions: elkguide and JTW
N
Nipper
84
136
Oklahoma
I'd suggest buying an anti rattle pin like this below. Cheap overseas dual hitch has lots of movement and this fixed mine from rattling and driving me crazy.
Amazon.com: The Hitch Titan Hitch Tightener | Anti-Rattle Hitch Pin Reduces Noise and Swaying | For Use with 1.25" or 2" Tow Hitch Receivers | Made of Heavy-Duty Black Powder Coated Steel: Automotive
Thanks waterfowler...i just ordered it. Have you loaded it much? Noticed any change in ride? I havent had a chance to load mine but id assume the self leveling suspension would help? Not planning on putting more than a loaded cooler on mine but, coldbeer gets heavy!
N
Nipper
84
136
Oklahoma
I was wondering how much that hitch would rattle.....figured it would drive a man crazy at low speeds.
Reactions: JTW
So this all reminds me...
I just have a solid shaft 3 ball hitch in mine right now.. this past weekend I noticed going down the trial when the rear suspension would compress it felt like I had something rubbing the tread on the tire. I could feel it but I couldn't find it. I finally stopped and looked and crawled all under it... just happens to pull myself up by the hitch and gave it a good shake. Sure enough, it was only rattling when I would hit a large enough bump and at just the right angle and speed.
H2oFowler
H2oFowler
40
89
Memphis,tn
Hadnt tried it out much as of yet. Don't think I'll have much more than a loaded yeti and some gear for the most part so let you know after this weekends use.
Thanks
H2oFowler
H2oFowler
40
89
Memphis,tn
That anti rattle piece is great... I have used them for years on other vehicles and former Rhino.
Reactions: Nipper and JTW
