P500 Rear facing LED light question.
Glazer
Glazer
24
78
Hello,
I am a new P5 owner and new to the forum.
Been doing a lot of reading and learning about the P5 and the useful mods you all have posted.
My question is - You that have rear facing LED lights on your P5. Do you find them to be a useful mod and how often do you find yourself using them.
Thank you for any help, Much appreciated. Mark from Michigan,
11,348
84,458
Welcome. Use a Northern Tool LED light often, and can swivel down for cab light. Thinking of putting the second one from 2 pack on front OEM roof lip. $15 for both.
D439E252 D7D1 45D6 8803 F230FA00C213 AEC9C32D 9F6E 4274 A461 4DAB98523579 455CB254 B038 45DD AEF8 151DC43094CF
Reactions: Glazer
158,420
Hello,
Only in the dark, lol!
Don't find myself using them that often but when you need them...;)
Reactions: Eltobgi and Glazer
Glazer
Glazer
24
78
Thank you Mudder and trigger for your reply. I'm going to install a couple of them tomorrow and give them a try.
It will be a good little project to do tomorrow in the garage with the wind storm they are calling for.
70Bones
70Bones
888
3,779
New Brunswick Canada
The first time I had to back up, after dark, with my new P500, I realized that back up lights were going to be important. Also, helps to see in the rear storage box, if you have one!
Reactions: Glazer and Mudder
JCart
JCart
897
2,024
Kamloops, BC Canada.
Mounted VisionX low amperage LED on rear of cab, works great for lighting things up on the rack and loading unloading out of the truck/trailer. For sure is a useful mod, suggest getting a low draw amp draw one.
Cheers,
j
Reactions: Glazer
Normanator22
Normanator22
46
137
GA
Hello,
Definitely. I mounted two up high on the back rails and I love having them there. As @trigger said, only use them when its dark, but it seems like I find more and more use for them. Even just around the house moving a trailer or loading it on the trailer and seeing to tie everything down. Let’s see the install!
5C5881FA 235D 4E94 AC7B 28F3F3543B39
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
I am a hunter so i sue mine all the time. Getting gear ready to head to deer stand, loading deer ad other game in back and as a back up light. One of my most used accessories.
Reactions: Glazer
Normanator22
Normanator22
46
137
GA
Since we are talking about lighting and hunting...two of my favorite things...
Check out the green led strips I put in. Very good for seeing in the cab at night, getting all my gear ready to go to the stand, etc. And I typically use a green headlamp so it was an easy decision.
45327280 E744 4DE4 8FE6 7826044D32F3 B67C5913 5A66 4A85 8077 2166F5C8AFA1 A903AA6E 1337 4185 B92F 88DA6DEA1938
Glazer
Glazer
24
78
Thanks you for all the reply's and the pic's, very helpful and much appreciated.
Yellowbeast
Yellowbeast
64
111
Pennsylvania
879E10B3 A450 433F B78A 7329B00A154C
Hello,
Hard to see in the pic but I mounted two pod led where the head rest r mounted and work great for backing in the shed or plowing at night
