If it's all stock, no add on battery, lights, larger bumper, etc. I can have it ready to roll in under a 30 minutes.
Pull the grille off with it, leave headlights and all attached.
Remove doors and fender flares first then the bolts and clips under the hood. There's one under the battery and another hidden one near the fuse box. I just shove all the electronics up under the dash, the only plug you should need to unplug is the headlights since they'll be coming off with the fender.
